Hello!
I’m trying to simulate a thin Deformable Body lying on a Rigidbody. My problem is that the Deformable Body falls through the Ridigbody as soon as I start the simulation as seen in “VisualMeshBeforeSimulation.png” and “VisualMeshDuringSimulation.png” in the provided zip-folder.
ExampleImages.zip (666.3 KB)
But if I turn on Show By Type > Physics > Deformable Body > Selected / All + Simulation / Collision in the UI the Deformable Body behaviour seems to be correct. (See “ColliderMeshes.png” and “SimulationMeshes.png”)
I already tried playing around with a lot of the Deformable Body settings like Simulation Mesh Resolution and Target Triangle Count, but the behaviour stays the same.
Is there any way I can fix this issue? I appreciate any help!
The behavior is the same with a thicker deformable?
Have you tried modifying the simulation tick?
Hi!
Thank you for your answer!
No, thicker bodies work - as far as I can tell - as intended.
Increasing the simulation tick rate does not change the behaviour.
Hi @kai.schlauersbach ,
The problem is likely that you haven’t tesselated your graphical mesh. The simulation can’t deform the graphical mesh unless it has sufficient resolution.
I suppose you used the create → mesh → cube to create the graphics mesh?
If so, you can do create → mesh → settings, then go to cube and adjust your resolutions, then rebuild your deformable. You might need to ctrl + double click the resolution fields, to enter values manually.
Cheers,
Simon
Thanks a lot, that did the trick!
