Hi
We tested the P40 USB disk by running KDiskMark on the Thor Dev Kit. The read speed was 993-1000 MB/s, while the write speed was only around 500 MB/s. Is this normal?
Hi
If this could matter, what usb ports does your board have and is disk attached to superspeed?
Here’s my dev kit:
lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 003: Dev 003, If 0, Class=Wireless, Driver=[none], 12M
|__ Port 003: Dev 003, If 1, Class=Wireless, Driver=[none], 12M
|__ Port 004: Dev 004, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 001: Dev 005, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 003: Dev 006, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 001: Dev 007, If 0, Class=Hub, Driver=hub/4p, 12M
|__ Port 001: Dev 008, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 001: Dev 008, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 001: Dev 008, If 2, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=tegra-xusb/4p, 10000M/x2
|__ Port 001: Dev 003, If 0, Class=Mass Storage, Driver=uas, 10000M
|__ Port 003: Dev 002, If 0, Class=Hub, Driver=hub/4p, 10000M
|__ Port 001: Dev 004, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 002: Dev 005, If 0, Class=Mass Storage, Driver=uas, 5000M
