I have the device in USB ForceRecovery Mode as per the install.
(Press ForceRecovery Button and Then power button and release together)
lsusb also shows NVIDIA corp.
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 004: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 013: ID 045e:07a5 Microsoft Corp. Wireless Receiver 1461C
Bus 001 Device 012: ID 045e:07a5 Microsoft Corp. Wireless Receiver 1461C
Bus 001 Device 004: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 016: ID 0955:7019 NVidia Corp.
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
But the install fails every time with the message below.
How can I proceed ? I was able to put 4.0 on it without issues.
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
0
remove any non mandatory device from your Jetson that may draw power
remove any hub or any other device from host while flashing
if the above doesn’t work, and if you’re using an old host, try inserting a recent USB hub between your host and Jetson, it might improve signal quality.
Use the type-C connector next to the power LED (the kit comes with a type-C to type-A cable useful for this). Hold the recovery button down (middle of the three), tap the power button, and release all. The power LED should be on, and the following command should show the Xavier is in recovery mode:
lsusb -d -955:7019
This is the prerequisite to complete prior to starting flash. Does it get that far? Does the error show despite seeing output from “lsusb -d 0955:7019”?
get_fuse_level
ECID tegrarcm_v2 /home/ssunil/Downloads/JetPack4.1/Xavier/Linux_for_Tegra/bootloader
hwchipid
Bus 001 Device 035: ID 0955:7019 NVidia Corp.
Bus 001 Device 024: ID 045e:07a5 Microsoft Corp. Wireless Receiver 1461C
Bus 001 Device 023: ID 045e:07a5 Microsoft Corp. Wireless Receiver 1461C
Bus 001 Device 017: ID 1050:0116 Yubico.com Yubikey NEO(-N) OTP+U2F+CCID
@Linuxdev thanks. Yes its not a VM and lsusb is consistent in showing the device when I put it into recovery mode. I suspect it has something to do with my PC’s USB 3.0 Roothub/Controller chip. I am going to attempt this with my laptop and see of this makes a difference. I hope its not h/w since this board is $$$. Actually I could put a USB analyzer inline and check too (I have a 3.0 analyzer), but dont want to spend too much time on it if my laptop works.
