Hi. I wanted to try out the new shader debugger feature in NSight Graphics, but I was struggling getting it to work.
Here’s an example project for reference, it’s one of Bevy’s examples GitHub - Andrewp2/wgpu_nsight_test
I have my main (linux ubuntu) desktop act as the target, and my laptop (linux ubuntu) act as the host.
The laptop runs this command in NSight WGPU_DEBUG=1; BEVY_ASSET_ROOT="/home/andrew-peterson/code/debug_test"; WGPU_BACKEND="vulkan";DISPLAY=":1"
The behavior I see is that the target does run the application, but the host hangs on “Searching for attachable processes on 192.168.1.36:49152-49215…”
sudo ss -tunlp does not show any process listening on any port in 49152 to 49215.
It seems that other activities don’t work either. Trying to launch the GPU Trace Profiler leads to
"Missing local file: /home/andrew-peterson/nvidia/NVIDIA-Nsight-Graphics-2024.2/target/linux-desktop-nomad-x64/GPUTraceVulkanLayer/vulkansc/implicit_layer.d/VK_LAYER_NV_GPU_Trace_release_public_2024_2_0.json
Missing required file. Re-installing the product may fix this issue"
I’m not sure why it says this, to install I ran the .run file just a few days ago, and then I launch it by doing sudo ./ngfx-ui in the “/home/andrew-peterson/nvidia/NVIDIA-Nsight-Graphics-2024.2/host/linux-desktop-nomad-x64” directory.
Ok I tried using the KhronosGroup Vulkan-Samples instead and it’s still not working, with the same issue. I suppose then it’s likely to be some issue with the setup?
running
Application Executable: /home/andrew-peterson/code/Vulkan-Samples/build/linux/app/bin/Release/x86_64/vulkan_samples
Working Directory: /home/andrew-peterson/code/Vulkan-Samples
Command Line Arguments: sample hello_triangle
Environment: DISPLAY=“:1”
I should add also that I can SSH from my host to my target successfully, and generate C++ capture seems to work just fine. The Shader Debugger is not working, however.
Updating drivers to version 555.58.02 did not help
Tried updating to the beta version of the driver 560, did not help
Ok I finally got something to attach by launching on the target, and then attaching on the host and updating all my drivers to 560.
