Try to Flash OS Jetson Orino Nx 16 GB Board on ubuntu 24.04 jetpack 6.21 download using NVIDIA SDK Manager
  1. Try to Flash OS Jetson Orino Nx 16 GB Board on ubuntu 24.04 jetpack 6.21 download using NVIDIA SDK Manager but not flash the os it wil be stuck in 50% not dont anything nect oly screen show like this
  2. Also try with Jetson Linux R35.4.1 version and command run sudo. /flash.sh p3768-0000+p3767-0000-nvme mnmeon1p1 cammand used for flash os it give me error at 0.5663 sudi this run & stuck external ssd is detect or not I was attaching my board photos and my actual Software screnshaot during Flashing OS time.
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the Jetson category where it’s more appropriate
Cheers,
Tom
Please make sure Orin NX in recovery mode before flashing.
Please refer Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation to check if in recovery mode.
I am trying to flash os on orino nx board recovery mode process as power off remove jumpers and power on the module but not flash the os please give me proper solution on this
Some questions to confirm:
  • Is your ubuntu a native or a virtual machine?
native
Please try following steps.
  1. reboot your host
  2. try other flashing cable
  3. try other usb port
The steps to put Orin NX in recovery mode as follow:
  • For the Jetson Orin Nano developer kit:
    1. Disconnect the power cable to ensure that the developer kit is powered off.
    2. Place a jumper to short the REC and GND pins on the 12-pin button header.
    3. Reconnect the power cable.
Also please record the serial console log during flashing and provide for us to review:
