Here are some of the things that I have tried to do. Help.
shawn@shawn-desktop:~$ sudo apt install nvidia-jetpack
[sudo] password for shawn:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-jetpack-dev : Depends: nvidia-tensorrt-dev (= 5.0.1-b118) but it is not going to be installed
Depends: nvidia-cuda-dev (= 5.0.1-b118) but 11.5.1-1ubuntu1 is to be installed
E: Unable to correct problems, you have held broken packages.
shawn@shawn-desktop:~$ sudo apt --fix-broken install -o Dpkg::Options::=“–force-overwrite”
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
shawn@shawn-desktop:~$ sudo apt show nvidia-tensorrt-dev
Package: nvidia-tensorrt-dev
Version: 5.0.1-b118
Priority: standard
Section: metapackages
Maintainer: NVIDIA Corporation
Installed-Size: 205 kB
Depends: libnvinfer-plugin-dev (= 8.4.0-1+cuda11.4), python3-libnvinfer (= 8.4.0-1+cuda11.4), python3-libnvinfer-dev (= 8.4.0-1+cuda11.4), libnvinfer-dev (= 8.4.0-1+cuda11.4), uff-converter-tf (= 8.4.0-1+cuda11.4), tensorrt (= 8.4.0.11-1+cuda11.4), libnvonnxparsers-dev (= 8.4.0-1+cuda11.4), libnvinfer-doc (= 8.4.0-1+cuda11.4), libnvparsers-dev (= 8.4.0-1+cuda11.4), graphsurgeon-tf (= 8.4.0-1+cuda11.4), libnvinfer-samples (= 8.4.0-1+cuda11.4), nvidia-tensorrt-runtime (= 5.0.1-b118)
Conflicts: nvidia-tensorrt-dev
Homepage: Autonomous Machines | NVIDIA Developer
Download-Size: 27.3 kB
APT-Sources: https://repo.download.nvidia.com/jetson/t234 r34.1/main arm64 Packages
Description: NVIDIA TensorRT dev Meta Package
shawn@shawn-desktop:~$ sudo apt show nvidia-jetpack-dev
Package: nvidia-jetpack-dev
Version: 5.0.1-b118
Priority: standard
Installed-Size: 199 kB
Depends: nvidia-l4t-jetson-multimedia-api (>> 34.1-0), nvidia-l4t-jetson-multimedia-api (<< 34.2-0), nvidia-jetpack-runtime (= 5.0.1-b118), nvidia-nsight-sys (= 5.0.1-b118), nvidia-tensorrt-dev (= 5.0.1-b118), nvidia-cuda-dev (= 5.0.1-b118), nvidia-vpi-dev (= 5.0.1-b118), nvidia-opencv-dev (= 5.0.1-b118), nvidia-cudnn8-dev (= 5.0.1-b118)
Download-Size: 29.4 kB
Description: NVIDIA Jetpack dev Meta Package
