I have some questions when I design the two orin module on one system. One module is set rootpoint and another is set endpoint.
1 what is the sequence for two module? Two SYS_VIN_HV 、two SYS_VIN_MV、two SYS_RESET_N、two MODULE_ POWER_ON、two CARRIER_ POWER_ON and others,how can I use these signal in the one system?Can you give some advice?
2 Many devices will connect to the two modules,does the module only controls the devices which connect to the itself?Or rootpoint module can control all devices?
3 Can rootpoint and endpoint module use one image ?
