TX2 Jetpack 4.6.1 building tensorflow
I have been trying to weeks to build tensorflow on Jetpack 4.5 through 4.6.3 and have had no success.
I found another post where someone had a similar problem and it was suggested to follow
I have attempted to do that several times without success. I just tried it with 4.6.1, since that is what person is the post was using. I run into an issue during the prereqs, any suggestions?
sudo pip3 install -U pip testresources setuptools==65.5.0
The directory ‘/home/nvidia/.cache/pip/http’ or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
The directory ‘/home/nvidia/.cache/pip’ or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Collecting pip
Downloading https://files.pythonhosted.org/packages/a4/6d/6463d49a933f547439d6b5b98b46af8742cc03ae83543e4d7688c2420f8b/pip-21.3.1-py3-none-any.whl (1.7MB)
100% |████████████████████████████████| 1.7MB 330kB/s
Collecting testresources
Downloading https://files.pythonhosted.org/packages/45/4d/79a9a1f71de22fbc6c6433ac135f68d005de72fbe73e2137d2e77da9252c/testresources-2.0.1-py2.py3-none-any.whl
Collecting setuptools==65.5.0
Could not find a version that satisfies the requirement setuptools==65.5.0 (from versions: 0.6b1, 0.6b2, 0.6b3, 0.6b4, 0.6rc1, 0.6rc2, 0.6rc3, 0.6rc4, 0.6rc5, 0.6rc6, 0.6rc7, 0.6rc8, 0.6rc9, 0.6rc10, 0.6rc11, 0.7.2, 0.7.3, 0.7.4, 0.7.5, 0.7.6, 0.7.7, 0.7.8, 0.8, 0.9, 0.9.1, 0.9.2, 0.9.3, 0.9.4, 0.9.5, 0.9.6, 0.9.7, 0.9.8, 1.0, 1.1, 1.1.1, 1.1.2, 1.1.3, 1.1.4, 1.1.5, 1.1.6, 1.1.7, 1.2, 1.3, 1.3.1, 1.3.2, 1.4, 1.4.1, 1.4.2, 2.0, 2.0.1, 2.0.2, 2.1, 2.1.1, 2.1.2, 2.2, 3.0, 3.0.1, 3.0.2, 3.1, 3.2, 3.3, 3.4, 3.4.1, 3.4.2, 3.4.3, 3.4.4, 3.5, 3.5.1, 3.5.2, 3.6, 3.7, 3.7.1, 3.8, 3.8.1, 4.0, 4.0.1, 5.0, 5.0.1, 5.0.2, 5.1, 5.2, 5.3, 5.4, 5.4.1, 5.4.2, 5.5, 5.5.1, 5.6, 5.7, 5.8, 6.0.1, 6.0.2, 6.1, 7.0, 8.0, 8.0.1, 8.0.2, 8.0.3, 8.0.4, 8.1, 8.2, 8.2.1, 8.3, 9.0, 9.0.1, 9.1, 10.0, 10.0.1, 10.1, 10.2, 10.2.1, 11.0, 11.1, 11.2, 11.3, 11.3.1, 12.0, 12.0.1, 12.0.2, 12.0.3, 12.0.4, 12.0.5, 12.1, 12.2, 12.3, 12.4, 13.0.1, 13.0.2, 14.0, 14.1, 14.1.1, 14.2, 14.3, 14.3.1, 15.0, 15.1, 15.2, 16.0, 17.0, 17.1, 17.1.1, 18.0, 18.0.1, 18.1, 18.2, 18.3, 18.3.1, 18.3.2, 18.4, 18.5, 18.6, 18.6.1, 18.7, 18.7.1, 18.8, 18.8.1, 19.0, 19.1, 19.1.1, 19.2, 19.3, 19.4, 19.4.1, 19.5, 19.6, 19.6.1, 19.6.2, 19.7, 20.0, 20.1, 20.1.1, 20.2.2, 20.3, 20.3.1, 20.4, 20.6.6, 20.6.7, 20.6.8, 20.7.0, 20.8.0, 20.8.1, 20.9.0, 20.10.1, 21.0.0, 21.1.0, 21.2.0, 21.2.1, 21.2.2, 22.0.0, 22.0.1, 22.0.2, 22.0.4, 22.0.5, 23.0.0, 23.1.0, 23.2.0, 23.2.1, 24.0.0, 24.0.1, 24.0.2, 24.0.3, 24.1.0, 24.1.1, 24.2.0, 24.2.1, 24.3.0, 24.3.1, 25.0.0, 25.0.1, 25.0.2, 25.1.0, 25.1.1, 25.1.2, 25.1.3, 25.1.4, 25.1.5, 25.1.6, 25.2.0, 25.3.0, 25.4.0, 26.0.0, 26.1.0, 26.1.1, 27.0.0, 27.1.0, 27.1.2, 27.2.0, 27.3.0, 27.3.1, 28.0.0, 28.1.0, 28.2.0, 28.3.0, 28.4.0, 28.5.0, 28.6.0, 28.6.1, 28.7.0, 28.7.1, 28.8.0, 28.8.1, 29.0.0, 29.0.1, 30.0.0, 30.1.0, 30.2.0, 30.2.1, 30.3.0, 30.4.0, 31.0.0, 31.0.1, 32.0.0, 32.1.0, 32.1.1, 32.1.2, 32.1.3, 32.2.0, 32.3.0, 32.3.1, 33.1.0, 33.1.1, 34.0.0, 34.0.1, 34.0.2, 34.0.3, 34.1.0, 34.1.1, 34.2.0, 34.3.0, 34.3.1, 34.3.2, 34.3.3, 34.4.0, 34.4.1, 35.0.0, 35.0.1, 35.0.2, 36.0.1, 36.1.0, 36.1.1, 36.2.0, 36.2.1, 36.2.2, 36.2.3, 36.2.4, 36.2.5, 36.2.6, 36.2.7, 36.3.0, 36.4.0, 36.5.0, 36.6.0, 36.6.1, 36.7.0, 36.7.1, 36.7.2, 36.8.0, 37.0.0, 38.0.0, 38.1.0, 38.2.0, 38.2.1, 38.2.3, 38.2.4, 38.2.5, 38.3.0, 38.4.0, 38.4.1, 38.5.0, 38.5.1, 38.5.2, 38.6.0, 38.6.1, 38.7.0, 39.0.0, 39.0.1, 39.1.0, 39.2.0, 40.0.0, 40.1.0, 40.1.1, 40.2.0, 40.3.0, 40.4.0, 40.4.1, 40.4.2, 40.4.3, 40.5.0, 40.6.0, 40.6.1, 40.6.2, 40.6.3, 40.7.0, 40.7.1, 40.7.2, 40.7.3, 40.8.0, 40.9.0, 41.0.0, 41.0.1, 41.1.0, 41.2.0, 41.3.0, 41.4.0, 41.5.0, 41.5.1, 41.6.0, 42.0.0, 42.0.1, 42.0.2, 43.0.0, 44.0.0, 44.1.0, 44.1.1, 45.0.0, 45.1.0, 45.2.0, 45.3.0, 46.0.0, 46.1.0, 46.1.1, 46.1.2, 46.1.3, 46.2.0, 46.3.0, 46.3.1, 46.4.0, 47.0.0, 47.1.0, 47.1.1, 47.2.0, 47.3.0, 47.3.1, 47.3.2, 48.0.0, 49.0.0, 49.0.1, 49.1.0, 49.1.1, 49.1.2, 49.1.3, 49.2.0, 49.2.1, 49.3.0, 49.3.1, 49.3.2, 49.4.0, 49.5.0, 49.6.0, 50.0.0, 50.0.1, 50.0.2, 50.0.3, 50.1.0, 50.2.0, 50.3.0, 50.3.1, 50.3.2, 51.0.0, 51.1.0, 51.1.0.post20201221, 51.1.1, 51.1.2, 51.2.0, 51.3.0, 51.3.1, 51.3.2, 51.3.3, 52.0.0, 53.0.0, 53.1.0, 54.0.0, 54.1.0, 54.1.1, 54.1.2, 54.1.3, 54.2.0, 56.0.0, 56.1.0, 56.2.0, 57.0.0, 57.1.0, 57.2.0, 57.3.0, 57.4.0, 57.5.0, 58.0.0, 58.0.1, 58.0.2, 58.0.3, 58.0.4, 58.1.0, 58.2.0, 58.3.0, 58.4.0, 58.5.0, 58.5.1, 58.5.2, 58.5.3, 59.0.1, 59.1.0, 59.1.1, 59.2.0, 59.3.0, 59.4.0, 59.5.0, 59.6.0)
No matching distribution found for setuptools==65.5.0
The instructions are for JetPack 5.0.2 which is Ubuntu 20.04.
For older release, please select one that is available on your environment.
Thanks, but do you have a link to those instructions?
The instructions listed in this forum do not work, TensorFlow for Jetson TX2! - #109 by Virat_Baahubali
I have tried 4.5, 4.6 etc.
The page only keeps the instructions for the latest software (JetPack 5.0.2).
Will find some place to share the instructions for JetPack 4.6.x and share with you.
We have updated the instructions for JetPack 4.6.3.
Please give it a try.
