Dear support!
We are currently using imx415c camera with xavier nx som on auvidea baseboard JNX30D the camera is working good with 4k@60fps. we wanted to use the same camera (imx415c) with jetson tx2 nx som on auvidea baseboard JNX30D.
we followed your documentation and selected the following combination
Imx415c camera
Vision Components MIPI CSI-2 camera driver
System on Module: TX2NX
Carrier Board: Auvidea_JNX30
L4T Driver Package (BSP): 32.7.3
Using build directory: /home/ubuntu18/vc_mipi_nvidia/build/Xavier_32.7.3
Using L4T Driver Package (BSP) URL: Developer Download Centers | NVIDIA Developer
Using L4T Driver Package (BSP) FILE: jetson_linux_r32.7.3_aarch64.tbz2
Using Sample Root Filesystem URL: Developer Download Centers | NVIDIA Developer
Using Sample Root Filesystem FILE: tegra_linux_sample-root-filesystem_r32.7.3_aarch64.tbz2
Using L4T Driver Package (BSP) Sources URL: Developer Download Centers | NVIDIA Developer
Using L4T Driver Package (BSP) Sources FILE: public_sources.tbz2
Using patches: kernel_common_32.3.1+ kernel_Xavier_32.7.3+
Using devicetree camera file: /home/ubuntu18/vc_mipi_nvidia/src/devicetree/Auvidea_JNX30D_TX2NX/tegra186-camera-vc-mipi-cam.dtsi
Using flash parameters: kernel-dtb jetson-xavier-nx-devkit-tx2-nx mmcblk0p1
Using target user and ip address: tx2@
we have raised a query with vision components they replied might be permission issue or usb issue or chip issue
for chip issue they informed that version D02 boards should use a patch
but we currently use AO3 version
Note:
We are not able to flash the device.
We are getting no error message but the flash process is not completed
Herewith iam attaching the terminal log for your reference
tx2nx_jnx30d_vc_mipi_imx415camera_terminal_log.txt (28.5 KB)
