I configured the device tree to control GPIO output and it turns out that GPIO pins G.0-5 won’t be HIGH until ubuntu OS is fully launched. On the other hand, J.0 pin becomes HIGH soon enough in boot procedure.
dts:
gpio@2200000 {
g0 {
gpio-hog;
gpios = <TEGRA_MAIN_GPIO(G, 0) 0>;
output-high;
label = "g0";
status = "okay";
j0 {
gpio-hog;
gpios = <TEGRA_MAIN_GPIO(J, 0) 0>;
output-high;
label = "j0";
status = "okay";
sdhci@3440000 {
status = "disabled";
Besides, G pins cannot be controlled from U-boot while J pins can.
Tegra186 (P2771-0000-500) # gpio toggle J0
gpio: pin J0 (gpio 72) value is 1
## -> J0 = HIGH
Tegra186 (P2771-0000-500) # gpio toggle G0
gpio: pin G0 (gpio 48) value is 1
## -> G0 = LOW
How can I use GPIO G pins in boot sequence?
I have found a statement in Jetson TX2 Series OEM Product Design Guide.
The SD_CARD & SDIO (TX2 4GB/TX2i only) pins are CZ type, but the associated power rails are not enabled at power-on – software enables these at a later time.
What exactly does the “software” mean? linux kernel?
hello peroxyacyl,
are you going to control these pin in the u-boot stage,
had you tried to modify the pinmux spreadsheets to update the pin configuration?
please refer to developer guide, Updating the Bootloader Pinmux.
thanks
Hello JerryChang,
Thank you for replay.
Yes
Of course I did. attaching excel screenshot.
hello peroxyacyl,
would like to double confirm you’ve use the python tool, $OUT/Linux_for_Tegra/kernel/pinmux/t186/pinmux-dts2cfg.py to output the cfg file,
after that, re-flash the board completely to apply the settings.
I used the script and flashed using the cfg files. I checked that a different pad voltage setting caused another behavior. I’m 100% sure about that.
hello peroxyacyl,
it’s uboot commands to control GPIO pins in u-boot,
according to tegra186-gpio.h, it’s correct you’re having pin number 48 for TEGRA_MAIN_GPIO(G, 0).
#define TEGRA_MAIN_GPIO(port, offset) \
((TEGRA_MAIN_GPIO_PORT_##port * 8) + offset)
could you please examine the pin status about, TEGRA_MAIN_GPIO(G, 0).
for example,
Usage:
gpio <input|set|clear|toggle> <pin>
- input/set/clear/toggle the specified pin
gpio status [-a] [<bank> | <pin>] - show [all/claimed] GPIOs
besides,
there’s GPIO APIs for cboot, could you please also have a try as below.
CBoot
there’s tegra GPIO driver API for reading a GPIO pin state.
for example,
$L4T_Sources/r32.5.1/Linux_for_Tegra/source/public/cboot/bootloader/partner/common/drivers/gpio/tegrabl_gpio.c
static tegrabl_error_t tegrabl_gpio_read(uint32_t gpio_num, gpio_pin_state_t *state, void *drv_data)
