We were using a modified version of https://gitlab.com/autowarefoundation/autoware.ai/drivers/tree/master/autoware_driveworks_gmsl_interface to run GMSL Cameras on ROS.
Now with the new Drive OS upgrade, we have refreshed the dependencies and fixed library names. Now the program compiles and we are able to:
Initialize a dwContextHandle_t
Initialize a dwSALHandle_t
but after when we do:
NvMediaDevice *device;
device = NvMediaDeviceCreate();
if (!device) {
std::cerr << "WOW: NvMediaDeviceCreate failed." << std::endl;
exit(1);
const uint32_t max_jpeg_size = 3 * 1290 * 1208;
NvMediaIJPE *jpegEncoder = NvMediaIJPECreate(device,
NvMediaSurfaceType_Image_YUV_420,
(uint8_t) 1,
max_jpeg_size);
if (!jpegEncoder) {
std::cerr << "WOW: NvMediaIJPECreate failed." << std::endl;
exit(1);
It prints:
[NvMediaIJPECreate:54] 1015 NvMediaSurfacetype is deprecated.
So after checking the documentation ( https://docs.nvidia.com/drive/drive_os_5.1.6.1L/nvvib_docs/DRIVE_OS_Linux_SDK_Development_Guide/baggage/group__surface__handling__api.html#ga334e1b66e894fdedccc4f6c280e65e90
) and the header file descriptions, I applied the following to fix it:
if (!device) {
exit(1);
NvMediaSurfFormatAttr attrs[7];
attrs[0].type = NvMediaSurfFormatAttrType::NVM_SURF_ATTR_SURF_TYPE;
attrs[0].value = NVM_SURF_ATTR_SURF_TYPE_YUV;
attrs[1].type = NvMediaSurfFormatAttrType::NVM_SURF_ATTR_LAYOUT;
attrs[1].value = NVM_SURF_ATTR_LAYOUT_BL;
attrs[2].type = NvMediaSurfFormatAttrType::NVM_SURF_ATTR_DATA_TYPE;
attrs[2].value = NVM_SURF_ATTR_DATA_TYPE_INT;
attrs[3].type = NvMediaSurfFormatAttrType::NVM_SURF_ATTR_MEMORY;
attrs[3].value = NVM_SURF_ATTR_MEMORY_PLANAR;
attrs[4].type = NvMediaSurfFormatAttrType::NVM_SURF_ATTR_SUB_SAMPLING_TYPE;
attrs[4].value = NVM_SURF_ATTR_SUB_SAMPLING_TYPE_422;
attrs[5].type = NvMediaSurfFormatAttrType::NVM_SURF_ATTR_BITS_PER_COMPONENT;
attrs[5].value = NVM_SURF_ATTR_BITS_PER_COMPONENT_8;
attrs[6].type = NvMediaSurfFormatAttrType::NVM_SURF_ATTR_COMPONENT_ORDER;
attrs[6].value = NVM_SURF_ATTR_COMPONENT_ORDER_YUV;
NvMediaSurfaceType surface_type = NvMediaSurfaceFormatGetType(attrs, 7);
std::cout << "surface_type: " << surface_type << std::endl;
(uint8_t) 1,
max_jpeg_size);
if (!jpegEncoder) {
exit(1);
It prints:
surface_type: 99999
[NvMediaIJPECreate:54] 99999 NvMediaSurfacetype is deprecated.
So the previous code used to work on Drive 8.0 and what am I missing to replicate the same behaviour using the new SDK?
