I have tried the following troubleshooting steps without success:
- Manually setting the DISPLAY environment variable as both
DISPLAY=:1 and DISPLAY="my ip:1".
- Verifying the display variable using
echo $DISPLAY, which shows the expected value.
- Rebooting the system after setting the DISPLAY environment variable, but the issue persists.
I suspect that there might be some additional configuration or settings required to ensure the VNC display works properly without an HDMI connection.
How can I configure the system to enable VNC display without the need for an HDMI connection?
Welcome to the NVIDIA Developer forums! Looks like you posted in the wrong category, so I went ahead and moved this to the Jeston forums for you.
Hi dana3amjad,
Please reference below topic steps.
system
Closed
6
