So, I’ve tried the solution below to access the Jetson without a monitor and edited the xorg.conf file as suggested. It didn’t work and now I cannot even access my jetson because the hdmi display is not showing anything… any ideas?
Continuing the discussion from Jetson Orin No monitor, VNC only splash screen until monitor connected :
Steps:
Reflash Jetpack 5.0.1 DP using SDKManager (follow instruction inside sdkmanager).
* Run commands according to this .
cd /usr/lib/systemd/user/graphical-session.target.wants
sudo ln -s ../vino-server.service ./.
gsettings set org.gnome.Vino prompt-enabled false
gsettings set org.gnome.Vino require-encryption false
gsettings set org.gnome.Vino authentication-methods “[‘vnc’]”
gsettings set org.gnome.Vino vnc-password $(echo -n ‘password’|base64)
3. Edit /etc/X11/xorg.conf. Add the following to the end of the file (according to README-vnc.txt)
Section “Screen”
Identifier “Default Screen”
Monitor “Configured Monitor”
Device “Tegra0”
SubSection “Display”
Depth 24
Virtual 1280 800 # Modify the resolution by editing these values
EndSubSection
EndSection
4. Sudo reboot now
5. Connect VNC viewer to Jetson Orin (splashscreen shown)</i>
Got it solved with ssh connection, thanks!
