Dear NVIDIA and community, Got my Orin development kit, I configured vino VNC, successfully connected few times and then end up changing xorg.config for screen resolution as explained in the readme-vnc.txt on Orin but now nothing, no VNC neither DP display. Just a splash screen in the startup and then blank.
I cannot even now restart from headless via usb serial. VNC client says ‘connection refused’
no SSH, nothing happens or comes up in force recovery mode.
Is there a way to change to initial xorg.config or something else ?
Please help me here.
As at the moment I don’t have anything on screen connected via Display port nor VNC. So what is the best way to Reset to state as out of factory and go back to very first time boot setup.
Some other users suggest to use noMachine. You can try that too.
Re-Flashed the Jetson, it was simple to flash. The long process was to get hold of x86 machine and Ubuntu installed. Rest was simple.
Thanks all
