I have followed all the steps according to this video. However, I am unable to find
/usr/local/driveworks/
folder on the host PC after successful flashing to Xavier A+B. Do you recommend installing a fresh copy of Linux and flash again?
I have the driveworks-1.2 from a old previous version of the software. But that one uses CUDA 9 and doesn’t work on the AGX platform, which has CUDA 10.0.
Is it possible to manually download the SDK and dw_samples from somewhere?
Can you please help me to get the latest version of driveworks?
Dear Oscar,
Did you select Host as well when flashing the board. Could you check installing again and let us know if you still face the issue. In step 3, you can actually see what all are installed on host machine.
Please refer to the image below https://photos.app.goo.gl/sTRC3vFLQznJwYVc8
I did try reinstalling a couple times actually and made sure I am using partners account, not the developer account and making sure everything is selected before installing.
Let me know if there is some command I need to run manually, feel free to point me in that direction.
Do you have an official release date that you can comment on?
But it still doesn’t solve the issue completely. The problem with the old software is that it flashes an image for AutoChauffer/AutoCruise images which seems to cause a conflict with CUDA versions. After cross-compiling the SDK samples and transfering them to the Dev board, it doesn’t find correct dynamic libraries(.so). Typing
ldd <binary_name>
shows that it is looking for the wrong CUDA version library. Some of the paths are not correct.
I don’t think I have access to DRIVE Software 8.0
2. Can you point me to a download URL or something?
