Hi, I am trying to flash an external USB Drive for booting AGX Xavier via an external USB stick. I connected both my AGX Xavier, and a 128GB USB stick to the host PC, and followed the instructions here:
However, I get the following error (l4t_flash_from_kernel: APP image is not found !!!):
writing item=15, 9:0:APP, 819875840, 30064771072, , , fixed-<reserved>-1,
[ 35]: l4t_flash_from_kernel: APP image /hdd1/sanaurrehman/NVIDIA_Flash/Own_NVIDIA_Flash/Jetpack_5p1p1/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/ is not found !!!
[ 35]: l4t_flash_from_kernel: Failed to write to APP
[ 35]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 35]: l4t_flash_from_kernel: Error flashing external device
Cleaning up...
How can I fix this? I have tried using a different USB stick, and trying a different BSP package (I tried using source files from Jetpack 5.1 and Jetpack 5.1.1, but same result).
The complete log from the host PC’s terminal after I execute the command for flashing is attached. MyLog.txt (125.0 KB)
Is your AGX Xavier a dev kit or a custom carrier board?
Our host requirement is Ubuntu 18.04/20.04 running on a physical machine, not a virtual machine(e.g. WSL, VirtualBox, VMware). Please check your host requirement.
@DavidDDD , the num_sectors field contains 119537664. The output of sudo fdisk -l /dev/sdd is as follows:
Disk /dev/sdd: 115.5 GiB, 123983626752 bytes, 242155521 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 2D42A321-194B-4DB7-B0E8-072D28584B45
Device Start End Sectors Size Type
/dev/sdd1 1601320 60321575 58720256 28G Microsoft basic data
/dev/sdd2 40 131111 131072 64M Microsoft basic data
/dev/sdd3 131112 132007 896 448K Microsoft basic data
/dev/sdd4 132008 197543 65536 32M Microsoft basic data
/dev/sdd5 197544 328615 131072 64M Microsoft basic data
/dev/sdd6 328616 329511 896 448K Microsoft basic data
/dev/sdd7 329512 395047 65536 32M Microsoft basic data
/dev/sdd8 395048 558887 163840 80M Microsoft basic data
/dev/sdd9 558888 559911 1024 512K Microsoft basic data
/dev/sdd10 559912 1174311 614400 300M Microsoft basic data
/dev/sdd11 1174312 1305383 131072 64M EFI System
/dev/sdd12 1305384 1469223 163840 80M Microsoft basic data
/dev/sdd13 1469224 1470247 1024 512K Microsoft basic data
/dev/sdd14 1470248 1601319 131072 64M Microsoft basic data
Partition table entries are not in disk order.
I have also tried using a custom xml file by just changing the num_sectors value to 242155521, as shown in the above command output, but I still get the exact same error.
This is the state of the USB after the flashing process had failed (these partitions were all created by the initrd flash script). I have tried formatting the USB before flash. I always create one ext4 partition. However, I am still getting the same error.
Ok. It seems I can flash the external USB drive if I use a different host (a laptop with Ubuntu 20.04). I did a clean install of Jetpack files in the new host machine, and was able to successfully flash the USB drive after that. So the problem is likely within the host machine. Strange, as I can use the flash.sh script without any issues in the old (already existing) host machine.
So in summary:
HOST A (Old Host, Ubuntu 18.04 PC): flash.sh works, but can’t flash the external USB drive.
HOST B (New Host, Ubuntu 20.04 Laptop): Can successfully flash the external USB drive.
Another thing I have observed: The bootable USB drive I created seems to work only with the specific dev kit that was connected to the host PC when the image was being flashed. Is it supposed to be like this? I was expecting that I would plug this USB into any dev kit, and that dev kit would boot from the USB. Is my understanding correct?
@DavidDDD , the Q&A you linked states that the Xavier should be able to boot from the external drive as long as it is also able to boot from its internal device (in case of AGX Xavier, the internal device is the EMMC).
However, what I observe is slightly different. I have two devkits, both of which are able to boot from internal EMMC just fine. Let’s say devkit A has username: abc, and devkit B has username def.
I created a external bootable USB image by connecting the USB, and the devkit A (in recovery mode) to my host PC. The flash process goes fine, and when I connect the USB to devkit A, it boots from USB correctly.
However, when I connect the USB to devkit B, it fails to boot from USB (devkit B boots from EMMC instead).
I then did an experiment, by flashing a new EMMC image to devkit B, and settting its username and password to the devkit A’s username and password (username: abc in this example). I then connected the USB to devkit B, and it boots from USB in devkit B as well.
Therefore, there seems to be a link between the username and password, and the USB image. How can I create an image that is independent of this?
I tried to create a new USB image ‘offline’ using the command:
sudo BOARDID=2888 BOARDSKU=0004 FAB=400 ./tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --external-device sda1 --direct sdd jetson-agx-xavier-devkit external
but it still only boots on devkit A, and not on devkit B, unless both devkits have same username and password (username: abc in this example).
@DavidDDD , I appreciate you continuing to help me. The issue is not in the boot order. The USB doesn’t show up in boot devices in the Boot Maintenance Manager in devkit B.
To answer your question, yes, both devkits have same Jetpack version (Jetpack 5.1)
I connect USB to host machine (Ubuntu 20.04), and format the USB drive so that it contains a single partition of ext4 type.
I go to Linux For Tegra folder, and enter the following command on terminal to flash an image to the USB: sudo BOARDID=2888 BOARDSKU=0004 FAB=400 ./tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --external-device sda1 --direct sdd jetson-agx-xavier-devkit external
After this process completes, I remove the USB from host, and connect it to devkit A. I power on devkit A, which successfully boots from USB. I remove USB, and power on devkit A. Devkit A successfully boots from EMMC. Hence, everything works great with devkit A.
I connect the USB to devkit B, and power on devkit B. Devkit B boots from EMMC. The USB does not show in devkit B’s UEFI menu, so I cannot change the boot order. (Note that the USB is working fine, as I can access the USB just fine in devkit B when devkit B boots from EMMC.
I connect devkit B to host machine (nothing else is connected to host), and flash a new EMMC image using flash.sh script. (sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1) When flashing is done, I set the username and password of new image to the username and password of devkit A.
I connect USB to devkit B, and power on devkit B. Devkit B successfully boots from USB.
Update: I think I have been able to resolve this issue. I flashed a new ‘offline’ USB image, but before creating this image, I deleted everything in the Linux_for_Tegra/tools/kernel_flash/images/external folder.
The image is flashed successfully, and I was able to boot from USB in both devkits without any dependency on username or password.
It is an interesting finding.
We will test in our side to check what’s goin on.
About the username and password, are you using l4t_create_default_user.sh or the OEM config to config the setting
Hi @DavidDDD . Apologies for the late reply. I am not using l4t_create_default_user.sh. I configure the username and password using the menu that appears when a device is flashed using flash.sh script. (I connect the devkit to an HDMI display).
