Unable to flash | Factory Reset
Hi, Currently I’m trying to reflash OS on my Jetson Orin Agx Developer Kit 64 GB, I’m new about this.
SO, There was Ubuntu OS on my Jetson device before,but now It wasn’t have. What should I do to reset everything and return to Factory Reset. I will send picture what I get while I turn on my Jetson Device.
I need fully guide to install OS and make Factory Reset from zero. (with all requirements and must-do things step by step).
I will appreciate If you provide me totally guide for me. Because I couldn’t find any relevant guides to solve my problem.
In the picture, What i am getting after turn on my Jetson Orin Agx:
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
How should my Host Machine requirements? Ubuntu 24.04 is mine OS
Please give me guide for this.
And how to get log from Jetson (UART).
Thank you!
Above reply has all the information. Please do read it first.
