Unable to install Isaac ROS packages via apt on ROS 2 Humble
The following pose-to-pose demo, which was previously working, suddenly stopped functioning. Upon checking the error logs, it seems that some packages are failing to install via apt. Could you please take a look and confirm?
Tutorial for Isaac Manipulator Reference Workflows with Isaac Sim — isaac_ros_docs documentation
Hi all,
The issue is currently fixed for US developers. For CN developers, it will be fixed tomorrow.
Keep us posted.
Best,
Raffaello
The same issue has occurred again since yesterday. Could you please address it?
Hi @k_m
I don’t see any issue related to the apt repos, but I’m forwarding your issue to the engineering for a double check.
Best,
Raffaello
Thank you for your comment.
After running the following command, the issue was resolved.
sudo curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
