Please check Where can i get the AC0002-0011-001-HH DC Power jack - #3 by Trumany
It is the one we recommend in our SCL and it is worth trying to see if it resolves your issue of intermittent contact causing system reset.
Thank you getting one now
Case is probably closed:15 hours and lots of cable movements later, the Jetson is (seemingly) still up. It’s not responding - current is down to 200mA (from the usual 300-400mA) - and tcp ports are closed - but that may be another problem. I forgot to look at the serial console, will do next time it happens.
Thank you for all the help!
Glad to know. Dodgy connectors did consume a lot of valuable resources, your time!
Thanks for the update.
