URDF Importer and Articulation Trouble
Hi, I am having trouble importing my URDF with the appropriate physics and joint constraints. I have made a camera gimbal model and exported the model as a URDF using a solidworks to URDF. Then, when importing the URDF to Isaacsim, I am able to see it, but when I simulate it, the physics do not work at all. The gimbal always shifts to the same angle and gets stuck there and does not abide by the physics. Note: the baselink (top mounting bracket) is fixed for this model.
The gimbal before looks normal (I would put a picture but cannot since I am a new user).
No matter the starting orientation before the simulation starts, here is the gimbal after:
I have confirmed it is not a problem with the model. This is probably a simple problem, but I have not been able to get it to work.
All help is appreciated!
Here is another example of where clearly the physics are wrong:
The top mounting bracket is fixed in space but the gimbal arms defy gravity.
please can you share the USD file, so that we can take a look how the simulation looks like?
Thanks,
Regards
Ales
Hey! I would also be interested in the URDF file. Could you share it somehow?
Hello!
We noticed that this topic hasn’t received any recent responses from the original poster, so we are closing it for now to help keep the forum organized.
If you’re still experiencing this issue or have additional questions, please feel free to create a GitHub Discussion or Issue in the Isaac Sim repository and include a link to this topic along with updated details. When doing so, we recommend mentioning or linking to this original topic in your new post—this helps provide context and makes it easier for others to assist you.
Best regards,
