Usb_hub can not be recognized when we use usb2.0 port2(pin 121,pin123) on orin nano
nvidia-jetpack version: 5.1.1
device tree is hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3768-0000-a0.dtsi.
we use default device tree:
Kernel configure use default configure:
when 1 use command “lsusb”, usb_hub not be found! usb_hub chip is RTS5411T-GR
We’ve fixed the issue, there’s something wrong with the hardware design! RTS5411T-GR chip entered Power saving mode! The usb_hub be found when we cancel the mode!
Glad to know issue fixed, thanks for the sharing.
