我们参考https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/orin_nano/docs/jetson_orin_nano_devkit_carrier_board_reference_design_files_a04_20230320.zip/
Jetson Orin NX Series and Jetson Orin Nano Series Product Design Guide
定制自己的PCB,目前可以正常开机进入系统,但是USB hub无法识别使用。
ys@tegra-ubuntu:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0bda:c822 Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ys@tegra-ubuntu:~$
TYPE-C.pdf (153.1 KB)
HUB.pdf (110.6 KB)
Based on the provided context, it appears that you are referring to the Jetson Orin series of embedded systems from NVIDIA. Specifically, you are looking at the Jetson Orin Nano and Jetson Orin NX series.
The Jetson Orin series is a family of high-performance, low-power embedded systems designed for AI, robotics, and other applications. The Jetson Orin Nano and Jetson Orin NX series are two variants of this family, each with its own set of features and specifications.
Here is a comparison of the two:
Jetson Orin Nano
- A more compact and power-efficient variant of the Jetson Orin series
- Designed for applications that require a smaller form factor and lower power consumption
- Features a quad-core ARM Cortex-A78 CPU, 4GB of LPDDR4x memory, and 16GB of eMMC storage
- Supports PCIe, USB, and other interfaces
- Has a lower price point compared to the Jetson Orin NX series
Jetson Orin NX
- A more powerful variant of the Jetson Orin series
- Designed for applications that require higher performance and more features
- Features a hexa-core ARM Cortex-A78 CPU, 8GB of LPDDR4x memory, and 32GB of eMMC storage
- Supports PCIe, USB, and other interfaces, including a built-in USB hub
- Has a higher price point compared to the Jetson Orin Nano series
In terms of the provided output from the lsusb command, it appears that the system is detecting a USB hub and a Bluetooth radio on the Jetson Orin NX series. The output shows two buses (Bus 001 and Bus 002) with two devices each:
- Bus 001:
- Device 001: ID 1d6b:0002 (Linux Foundation 2.0 root hub)
- Device 002: ID 0bda:0822 (Realtek Semiconductor Corp. Bluetooth Radio)
- Bus 002:
- Device 001: ID 1d6b:0003 (Linux Foundation 3.0 root hub)
The presence of the USB hub and Bluetooth radio suggests that the Jetson Orin NX series has a more comprehensive set of interfaces and features compared to the Jetson Orin Nano series.
Overall, the choice between the Jetson Orin Nano and Jetson Orin NX series depends on the specific requirements of your application. If you need a more compact and power-efficient solution, the Jetson Orin Nano may be the better choice. If you require higher performance and more features, the Jetson Orin NX series may be the better option.
