Hello I would like to use using Audio2Face in offline mod, it worked in early versions, using windows 10 latest.
Its works if i have internet connection and shut internet connection down i can use Audio2Face if I have logged in while i was connected. would be great to start up Audio2Face on laptop without having a connection.
Thanks Audio2Face comming along great, suggestion have memory shortcuts in viewer when jumping between meshes when doing mesh fitting, specially when inside mouth, cant find a wireframe mode that works, have rtx 4090.
While Launcher needs internet connection, you can run Audio2Face directly from the installation folder instead of using Launcher. It’s usually installed in a folder like this on Windows: C:\Users\{USER}\AppData\Local\ov\pkg\prod-audio2face-2022.2.1\audio2face.kit.bat
You can turn on wireframe mode from RTX-Realtime -> Wireframe.
By default, the wireframe is too thick, so you might not see any change in the viewport. Reduce wireframe thickness from Render Settings -> Common -> Wireframe Settings -> Thickness
works fine, cant change thickness value lower than 0.1, but i can change render meter per unit from default to big, medium or small then i see wireframe. Can probably insert 0.01 thickness when I find the settings file responsible for the render settings.
running a2f offline works great on both win 10 and win 11(laptop).
