Using Jetson Clocks
How to undo the command “sudo jetson_clocks” I just type it to the terminal without using the command “sudo jetson_clocks --store”. After doing that code my jetson nano always freezes and the wallpaper is not loading after bootup.
What do you mean with undo?
It should go back to the default mode after you reboot the device.
