Is it possible to use two Sekonix AR0231 gmsl cameras with the Jetson nano? Can you suggest a way to do that so that I can use the Driveworks SDK for the camera?
Regards,
Gibin
Regards,
Gibin
Hi gibin.zachariah,
We have tested a setup with 6 Sekonix AR0231 GMSL sensors working on Jetson TX2 with a sensor driver support.
Here is the reference:
[url]https://developer.ridgerun.com/wiki/index.php?title=JetsonTX2/Supported_camera_sensors/ON_Semiconductor_AR0231_Linux_driver_for_Jetson_TX2[/url]
In your case you would need a similar driver to work on Jetson Nano and some device-tree changes would be needed depending on the hardware (interface board) that you are want use to perform the connections between the camera sensors and the Jetson system.
Regards,
-Enrique
