I’m working on a carrier board design for the AGX Orin Industrial module and am trying to figure out the base requirements for the power signals. In the design guide, VDDIN_PWR_BAD_N is described as
“VDD_IN Power Bad: Carrier board indication to module that
VDD_IN power is not valid. Carrier board should stop
asserting this signal and allow on-module pull-up to bring
high only when HV/MV are stable and have have reached
required voltage levels.”
My reading of this is that it should be deasserted when SYS_VIN_MV and SYS_VIN_HV are stable however the dev kit seems to treat this as a watch signal for the jack input voltage, not the voltage to the actual module. (it does not have any logic at all related to SYS_VIN_MV for example). which interpretation is correct? if the first, what is the explanation for the dev kit design?
Teva
