Virtual channel, X2 Lane configuration,camera_error
Hi ,
Nx nvidia_jetson_ 32.4.2 , we use two 96705 - > 9296 - > SOC (NX), virtual channel, X2 Lane configuration.
Our device tree configuration is
host1x {
	status = "ok";
	vi@15c10000 {
		status = "ok";
		num-channels = <8>;
		ports {
			status = "ok";
			#address-cells = <1>;
			#size-cells = <0>;
			port@6 {
				status = "ok";
				reg = <6>;
				imx185_vi_in6: endpoint {
						status = "ok";
						vc-id = <0>;
						port-index = <5>;
						bus-width = <2>;
						remote-endpoint = <&imx185_csi_out6>;
			port@7 {
				status = "ok";
				reg = <7>;
				imx185_vi_in7: endpoint {
						status = "ok";
						vc-id = <1>;
						port-index = <5>;
						bus-width = <2>;
						remote-endpoint = <&imx185_csi_out7>;
	nvcsi@15a00000 {
		status = "ok";
		num-channels = <8>;
		#size-cells = <0>;
		channel@6 {
			status = "ok";
			reg = <6>;
			ports {
				status = "ok";
				#size-cells = <0>;
				port@0 {
					status = "ok";
					reg = <0>;
					imx185_csi_in6: endpoint@12 {
						status = "ok";
						port-index = <6>;
						bus-width = <2>;
						remote-endpoint = <&imx185_imx185_out6>;
				port@1 {
					status = "ok";
					reg = <1>;
					imx185_csi_out6: endpoint@13 {
						status = "ok";
						remote-endpoint = <&imx185_vi_in6>;
		channel@7 {
			status = "ok";
			reg = <7>;
			ports {
				status = "ok";
				#size-cells = <0>;
				port@0 {
					status = "ok";
					reg = <0>;
					imx185_csi_in7: endpoint@14 {
						status = "ok";
						port-index = <6>;
						bus-width = <2>;
						remote-endpoint = <&imx185_imx185_out7>;
				port@1 {
					status = "ok";
					reg = <1>;
					imx185_csi_out7: endpoint@15 {
						status = "ok";
						remote-endpoint = <&imx185_vi_in7>;
i2c@3160000 {
	status = "okay";
	imx185_g@21 {
		compatible = "nvidia,imx185";
		clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
         		<&bpmp_clks TEGRA194_CLK_EXTPERIPH1>;
        		clock-names = "extperiph1", "pllp_grtba";
        		mclk = "extperiph1";
		reg = <0x21>;
		devnode = "video6";
		physical_w = "15.0";
		physical_h = "12.5";
		sensor_model ="imx185_g";
		delayed_gain = "true";
		use_sensor_mode_id = "true";
		limit_analog_gain = "true";
		post_crop_frame_drop = "0";
		use_decibel_gain = "true";
		mode0 {
			mclk_khz = "37125";
			num_lanes = "2";
			tegra_sinterface = "serial_g";
			vc_id = "0";
			phy_mode = "DPHY";
			discontinuous_clk = "no";
			dpcm_enable = "false";
			cil_settletime = "0";
			dynamic_pixel_bit_depth = "16";
			csi_pixel_bit_depth = "16";
			mode_type = "yuv";
			pixel_phase = "yuyv";
			active_w = "1920";
			active_h = "1080";
			readout_orientation = "0";
			line_length = "2200";
			inherent_gain = "1";
			mclk_multiplier = "2";
			//pix_clk_hz = "72000000";
			//pix_clk_hz = "288000000";
			//pix_clk_hz = "400000000";
			pix_clk_hz   = "742500000";
			gain_factor = "10";
			min_gain_val = "0";
			max_gain_val = "480";
			step_gain_val = "3";
			default_gain ="0";
			min_hdr_ratio = "1";
			max_hdr_ratio = "1";
			framerate_factor = "1000000";
			min_framerate = "1500000";
			max_framerate = "30000000";
			step_framerate = "1";
			default_framerate = "30000000";
			exposure_factor = "1000000";
			min_exp_time = "30";
			max_exp_time = "660000";
			step_exp_time = "1";
			default_exp_time = "33334";
			embedded_metadata_height = "0";
		ports {
            #size-cells = <0>;
			port@0 {
				status = "ok";
				reg = <0>;
				imx185_imx185_out6: endpoint {
					status = "ok";
					vc-id = <0>;
					port-index = <6>;
					bus-width = <2>;
					remote-endpoint = <&imx185_csi_in6>;
    imx185_h@22 {
		reg = <0x22>;
		devnode = "video7";
		sensor_model ="imx185_h";
		mode0 {
			mclk_khz = "37125";
			num_lanes = "2";
			tegra_sinterface = "serial_h";
			vc_id = "1";
			phy_mode = "DPHY";
			mode_type = "yuv";
			active_w = "1920";
			active_h = "1080";
			gain_factor = "10";
			min_gain_val = "0";
			default_gain ="0";
		ports {
            #size-cells = <0>;
			port@0 {
				status = "ok";
				reg = <0>;
				imx185_imx185_out7: endpoint {
					status = "ok";
					vc-id = <1>;
					port-index = <6>;
					bus-width = <2>;
					remote-endpoint = <&imx185_csi_in7>;
The configuration of our 9296 can output the camera data of a certain channel separately, but when the fusion data is output, there will be no image. It is reasonable that the single channel data output is no problem, and the fusion should also be OK. It is not clear whether there will be more data after fusion, or whether there will be an unknown problem with Nx x2 lane.
Video 6 doesn’t show an image. I recorded trace information
kworker/0:2-992 [000] … 81.958695: rtos_queue_peek_from_isr_failed: tstamp:2898876171 queue:0x0bcbcf78
kworker/0:2-992 [000] … 82.126685: rtos_queue_peek_from_isr_failed: tstamp:2903876171 queue:0x0bcbcf78
kworker/0:2-992 [000] … 82.294734: rtos_queue_peek_from_isr_failed: tstamp:2908876174 queue:0x0bcbcf78
kworker/0:2-992 [000] … 82.462689: rtos_queue_peek_from_isr_failed: tstamp:2913876172 queue:0x0bcbcf78
kworker/0:2-992 [000] … 82.630677: rtos_queue_peek_from_isr_failed: tstamp:2918876171 queue:0x0bcbcf78
kworker/0:2-992 [000] … 82.798685: rtos_queue_peek_from_isr_failed: tstamp:2923876172 queue:0x0bcbcf78
kworker/0:2-992 [000] … 82.910731: rtos_queue_peek_from_isr_failed: tstamp:2928876172 queue:0x0bcbcf78
kworker/0:2-992 [000] … 83.078672: rtos_queue_peek_from_isr_failed: tstamp:2933876172 queue:0x0bcbcf78
kworker/0:2-992 [000] … 83.246697: rtos_queue_peek_from_isr_failed: tstamp:2938876171 queue:0x0bcbcf78
kworker/0:2-992 [000] … 83.358696: rtos_queue_peek_from_isr_failed: tstamp:2941774069 queue:0x0bcbcf78
v4l2-ctl-8171 [002] … 91.642263: tegra_channel_open: vi-output, imx185 0-0021
v4l2-ctl-8171 [000] … 91.643628: tegra_channel_set_power: imx185 0-0021 : 0x1
v4l2-ctl-8171 [000] … 91.643643: camera_common_s_power: status : 0x1
v4l2-ctl-8171 [000] … 91.643952: tegra_channel_set_power: 15a00000.nvcsi–2 : 0x1
v4l2-ctl-8171 [000] … 91.643955: csi_s_power: enable : 0x1
v4l2-ctl-8171 [000] … 91.652277: vb2_qbuf: owner = ffffffc1a5dc9a80, queued = 1, owned_by_drv = 0, index = 0, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.652283: v4l2_qbuf: minor = 18, index = 0, type = VIDEO_CAPTURE, bytesused = 4147200, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-8171 [000] … 91.652527: vb2_qbuf: owner = ffffffc1a5dc9a80, queued = 2, owned_by_drv = 0, index = 1, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.652530: v4l2_qbuf: minor = 18, index = 1, type = VIDEO_CAPTURE, bytesused = 4147200, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-8171 [000] … 91.652783: vb2_qbuf: owner = ffffffc1a5dc9a80, queued = 3, owned_by_drv = 0, index = 2, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.652785: v4l2_qbuf: minor = 18, index = 2, type = VIDEO_CAPTURE, bytesused = 4147200, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-8171 [000] … 91.653015: vb2_qbuf: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 0, index = 3, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.653017: v4l2_qbuf: minor = 18, index = 3, type = VIDEO_CAPTURE, bytesused = 4147200, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-8171 [000] … 91.653023: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 1, index = 0, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.653026: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 2, index = 1, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.653027: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.653028: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 4147200, timestamp = 0
v4l2-ctl-8171 [000] … 91.653111: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
v4l2-ctl-8171 [001] … 91.676995: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-8171 [001] … 91.681540: tegra_channel_set_stream: 15a00000.nvcsi–2 : 0x1
v4l2-ctl-8171 [001] … 91.681544: csi_s_stream: enable : 0x1
v4l2-ctl-8171 [001] … 91.681553: tegra_channel_set_stream: imx185 0-0021 : 0x1
kworker/0:2-992 [000] … 91.710727: rtos_queue_peek_from_isr_failed: tstamp:3202293674 queue:0x0bcbcf78
kworker/0:2-992 [000] … 91.710732: rtcpu_start: tstamp:3202295971
kworker/0:2-992 [000] … 91.710734: rtos_queue_send_from_isr_failed: tstamp:3202310013 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.710736: rtos_queue_send_from_isr_failed: tstamp:3202310162 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.710737: rtos_queue_send_from_isr_failed: tstamp:3202310311 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.710738: rtos_queue_send_from_isr_failed: tstamp:3202310459 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.710739: rtos_queue_send_from_isr_failed: tstamp:3202310606 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.710741: rtcpu_string: tstamp:3202311036 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-992 [000] … 91.710772: rtcpu_string: tstamp:3202311213 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:2-992 [000] … 91.710783: rtcpu_string: tstamp:3202311469 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:2-992 [000] … 91.710792: rtcpu_string: tstamp:3202311736 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:2-992 [000] … 91.710801: rtcpu_string: tstamp:3202311970 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:2-992 [000] … 91.710809: rtcpu_string: tstamp:3202312202 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:2-992 [000] … 91.710817: rtcpu_string: tstamp:3202312434 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:2-992 [000] … 91.710861: rtcpu_string: tstamp:3202320843 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/0:2-992 [000] … 91.710863: rtcpu_string: tstamp:3202320960 id:0x04010000 str:"on 2.2
kworker/0:2-992 [000] … 91.710873: rtos_queue_send_from_isr_failed: tstamp:3202968090 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.710874: rtos_queue_send_from_isr_failed: tstamp:3202968260 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.710875: rtos_queue_send_from_isr_failed: tstamp:3202968414 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.710877: rtos_queue_send_from_isr_failed: tstamp:3202968562 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.710878: rtos_queue_send_from_isr_failed: tstamp:3202968707 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.710879: rtcpu_string: tstamp:3202969590 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:2-992 [000] … 91.710889: rtcpu_vinotify_event: tstamp:3203011386 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3710820320 data:0x10000000
kworker/0:2-992 [000] … 91.710920: rtcpu_vinotify_event: tstamp:3203011537 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3710829056 data:0x31000001
kworker/0:2-992 [000] … 91.710921: rtcpu_vinotify_event: tstamp:3203011700 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3710831200 data:0x07020001
kworker/0:2-992 [000] … 91.710922: rtcpu_vinotify_event: tstamp:3203011838 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3710865088 data:0x10000000
kworker/0:2-992 [000] … 91.710923: rtcpu_vinotify_event: tstamp:3203011997 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3710873472 data:0x31000002
kworker/0:2-992 [000] … 91.710925: rtos_queue_send_from_isr_failed: tstamp:3203112883 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.710926: rtos_queue_send_from_isr_failed: tstamp:3203113034 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.710927: rtos_queue_send_from_isr_failed: tstamp:3203113187 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.710928: rtos_queue_send_from_isr_failed: tstamp:3203113335 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.710929: rtos_queue_send_from_isr_failed: tstamp:3203113482 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.710931: rtcpu_vinotify_error: tstamp:3203122570 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3203119446 data:0x00100000
kworker/0:2-992 [000] … 91.710932: rtcpu_vinotify_error: tstamp:3203123335 tag:CSIMUX_STREAM channel:0x00 frame:1024 vi_tstamp:3203120071 data:0x00100000
kworker/0:2-992 [000] … 91.710933: rtcpu_vinotify_event: tstamp:3203554157 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3203119446 data:0x00100000
kworker/0:2-992 [000] … 91.710935: rtcpu_vinotify_event: tstamp:3203554323 tag:CSIMUX_STREAM channel:0x00 frame:1024 vi_tstamp:3203120071 data:0x00100000
kworker/0:2-992 [000] … 91.710941: rtcpu_vinotify_error: tstamp:3204016762 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3204013944 data:0x000003c9
vi-output, imx1-8173 [001] … 91.742828: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 91.742832: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 0, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 91.766714: rtcpu_vinotify_event: tstamp:3204096349 tag:FS channel:0x00 frame:0 vi_tstamp:3203686561 data:0x00000015
kworker/0:2-992 [000] … 91.766717: rtcpu_vinotify_event: tstamp:3204096516 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3203686564 data:0x00000000
kworker/0:2-992 [000] … 91.766719: rtcpu_vinotify_event: tstamp:3204096660 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3203687774 data:0x00000001
kworker/0:2-992 [000] … 91.766720: rtcpu_vinotify_event: tstamp:3204096823 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3733765184 data:0x08020001
kworker/0:2-992 [000] … 91.766721: rtcpu_vinotify_event: tstamp:3204096959 tag:FS channel:0x01 frame:0 vi_tstamp:3204012732 data:0x00000015
kworker/0:2-992 [000] … 91.766722: rtcpu_vinotify_event: tstamp:3204097115 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3204013944 data:0x000003c9
kworker/0:2-992 [000] … 91.766723: rtcpu_vinotify_event: tstamp:3205013728 tag:FE channel:0x00 frame:0 vi_tstamp:3205008729 data:0x00000025
kworker/0:2-992 [000] … 91.766724: rtcpu_vinotify_event: tstamp:3205013890 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3205008729 data:0x01000000
kworker/0:2-992 [000] … 91.766727: rtcpu_vinotify_event: tstamp:3205014029 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3776049216 data:0x01020001
kworker/0:2-992 [000] … 91.766758: rtos_queue_send_from_isr_failed: tstamp:3205028767 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.766759: rtos_queue_send_from_isr_failed: tstamp:3205028919 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.766761: rtos_queue_send_from_isr_failed: tstamp:3205029074 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.766762: rtos_queue_send_from_isr_failed: tstamp:3205029222 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.766763: rtos_queue_send_from_isr_failed: tstamp:3205029369 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.766769: rtcpu_vinotify_error: tstamp:3205437106 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3205434285 data:0x000003c9
kworker/0:2-992 [000] … 91.766770: rtcpu_vinotify_event: tstamp:3205507216 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3205008731 data:0x00000000
kworker/0:2-992 [000] … 91.766771: rtcpu_vinotify_event: tstamp:3205507360 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3776088608 data:0x07020002
kworker/0:2-992 [000] … 91.766772: rtcpu_vinotify_event: tstamp:3205507522 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3776338048 data:0x10000000
kworker/0:2-992 [000] … 91.766773: rtcpu_vinotify_event: tstamp:3205507670 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3776367776 data:0x31000003
kworker/0:2-992 [000] … 91.766774: rtcpu_vinotify_event: tstamp:3205507828 tag:FS channel:0x00 frame:0 vi_tstamp:3205106904 data:0x00000015
kworker/0:2-992 [000] … 91.766776: rtcpu_vinotify_event: tstamp:3205507968 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3205106906 data:0x00000000
kworker/0:2-992 [000] … 91.766777: rtcpu_vinotify_event: tstamp:3205508125 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3205108116 data:0x00000001
kworker/0:2-992 [000] … 91.766778: rtcpu_vinotify_event: tstamp:3205508260 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3779216160 data:0x08020002
kworker/0:2-992 [000] … 91.766779: rtcpu_vinotify_event: tstamp:3205508431 tag:FE channel:0x01 frame:0 vi_tstamp:3205335082 data:0x00000025
kworker/0:2-992 [000] … 91.766780: rtcpu_vinotify_event: tstamp:3205508566 tag:FS channel:0x01 frame:0 vi_tstamp:3205433073 data:0x00000015
kworker/0:2-992 [000] … 91.766781: rtcpu_vinotify_event: tstamp:3205508719 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3205434285 data:0x000003c9
vi-output, imx1-8173 [001] … 91.788171: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 1, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 91.788175: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 1, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 91.822670: rtcpu_vinotify_event: tstamp:3206434064 tag:FE channel:0x00 frame:0 vi_tstamp:3206429069 data:0x00000025
kworker/0:2-992 [000] … 91.822673: rtcpu_vinotify_event: tstamp:3206434230 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3206429070 data:0x01000000
kworker/0:2-992 [000] … 91.822674: rtcpu_vinotify_event: tstamp:3206434370 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3821500064 data:0x01020002
kworker/0:2-992 [000] … 91.822675: rtcpu_vinotify_event: tstamp:3206434532 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3206429072 data:0x00000000
kworker/0:2-992 [000] … 91.822677: rtcpu_vinotify_event: tstamp:3206434669 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3821532928 data:0x07020003
kworker/0:2-992 [000] … 91.822679: rtos_queue_send_from_isr_failed: tstamp:3206445437 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.822680: rtos_queue_send_from_isr_failed: tstamp:3206445590 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.822681: rtos_queue_send_from_isr_failed: tstamp:3206445743 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.822682: rtos_queue_send_from_isr_failed: tstamp:3206445895 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.822684: rtos_queue_send_from_isr_failed: tstamp:3206446041 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.822691: rtcpu_vinotify_error: tstamp:3206857448 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3206854625 data:0x000003c9
kworker/0:2-992 [000] … 91.822692: rtcpu_vinotify_event: tstamp:3206972106 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3821768832 data:0x10000000
kworker/0:2-992 [000] … 91.822694: rtcpu_vinotify_event: tstamp:3206972249 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3821798592 data:0x31000004
kworker/0:2-992 [000] … 91.822695: rtcpu_vinotify_event: tstamp:3206972412 tag:FS channel:0x00 frame:0 vi_tstamp:3206527246 data:0x00000015
kworker/0:2-992 [000] … 91.822696: rtcpu_vinotify_event: tstamp:3206972555 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3206527249 data:0x00000000
kworker/0:2-992 [000] … 91.822697: rtcpu_vinotify_event: tstamp:3206972714 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3206528458 data:0x00000001
kworker/0:2-992 [000] … 91.822698: rtcpu_vinotify_event: tstamp:3206972849 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3824667104 data:0x08020003
kworker/0:2-992 [000] … 91.822699: rtcpu_vinotify_event: tstamp:3206973003 tag:FE channel:0x01 frame:0 vi_tstamp:3206755425 data:0x00000025
kworker/0:2-992 [000] … 91.822700: rtcpu_vinotify_event: tstamp:3206973138 tag:FS channel:0x01 frame:0 vi_tstamp:3206853413 data:0x00000015
kworker/0:2-992 [000] … 91.822702: rtcpu_vinotify_event: tstamp:3206973294 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3206854625 data:0x000003c9
kworker/0:2-992 [000] … 91.822704: rtos_queue_peek_from_isr_failed: tstamp:3207294048 queue:0x0bcbcf78
vi-output, imx1-8173 [001] … 91.833545: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 91.833548: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 2, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 91.878687: rtcpu_vinotify_event: tstamp:3207859725 tag:FE channel:0x00 frame:0 vi_tstamp:3207849409 data:0x00000025
kworker/0:2-992 [000] … 91.878690: rtcpu_vinotify_event: tstamp:3207859891 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3207849410 data:0x01000000
kworker/0:2-992 [000] … 91.878692: rtcpu_vinotify_event: tstamp:3207860035 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3866950944 data:0x01020003
kworker/0:2-992 [000] … 91.878693: rtcpu_vinotify_event: tstamp:3207860199 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3207849412 data:0x00000000
kworker/0:2-992 [000] … 91.878694: rtcpu_vinotify_event: tstamp:3207860339 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3866983776 data:0x07020004
kworker/0:2-992 [000] … 91.878695: rtcpu_vinotify_event: tstamp:3207860498 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3867158496 data:0x10000000
kworker/0:2-992 [000] … 91.878696: rtcpu_vinotify_event: tstamp:3207860633 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3867188224 data:0x31000005
kworker/0:2-992 [000] … 91.878698: rtos_queue_send_from_isr_failed: tstamp:3207863224 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.878699: rtos_queue_send_from_isr_failed: tstamp:3207863378 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.878701: rtos_queue_send_from_isr_failed: tstamp:3207863528 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.878702: rtos_queue_send_from_isr_failed: tstamp:3207863676 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.878703: rtos_queue_send_from_isr_failed: tstamp:3207863821 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.878710: rtcpu_vinotify_error: tstamp:3208277819 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3208274965 data:0x000003c9
kworker/0:2-992 [000] … 91.878711: rtcpu_vinotify_event: tstamp:3208382967 tag:FS channel:0x00 frame:0 vi_tstamp:3207947589 data:0x00000015
kworker/0:2-992 [000] … 91.878712: rtcpu_vinotify_event: tstamp:3208383112 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3207947591 data:0x00000000
kworker/0:2-992 [000] … 91.878802: rtcpu_vinotify_event: tstamp:3208383274 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3207948801 data:0x00000001
kworker/0:2-992 [000] … 91.878804: rtcpu_vinotify_event: tstamp:3208383413 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3870118080 data:0x08020004
kworker/0:2-992 [000] … 91.878805: rtcpu_vinotify_event: tstamp:3208383574 tag:FE channel:0x01 frame:0 vi_tstamp:3208175768 data:0x00000025
kworker/0:2-992 [000] … 91.878806: rtcpu_vinotify_event: tstamp:3208383709 tag:FS channel:0x01 frame:0 vi_tstamp:3208273754 data:0x00000015
kworker/0:2-992 [000] … 91.878807: rtcpu_vinotify_event: tstamp:3208383867 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3208274965 data:0x000003c9
vi-output, imx1-8173 [001] … 91.879046: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 3, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 91.879050: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 91.924487: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 91.924490: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 0, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 91.934674: rtos_queue_send_from_isr_failed: tstamp:3209285254 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.934678: rtos_queue_send_from_isr_failed: tstamp:3209285411 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.934679: rtos_queue_send_from_isr_failed: tstamp:3209285564 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.934680: rtos_queue_send_from_isr_failed: tstamp:3209285712 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.934681: rtos_queue_send_from_isr_failed: tstamp:3209285857 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.934683: rtcpu_vinotify_event: tstamp:3209373147 tag:FE channel:0x00 frame:0 vi_tstamp:3209269749 data:0x00000025
kworker/0:2-992 [000] … 91.934685: rtcpu_vinotify_event: tstamp:3209373309 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3209269750 data:0x01000000
kworker/0:2-992 [000] … 91.934686: rtcpu_vinotify_event: tstamp:3209373449 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3912401824 data:0x01020004
kworker/0:2-992 [000] … 91.934687: rtcpu_vinotify_event: tstamp:3209373611 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3209269752 data:0x00000000
kworker/0:2-992 [000] … 91.934688: rtcpu_vinotify_event: tstamp:3209373750 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3912434688 data:0x07020005
kworker/0:2-992 [000] … 91.934716: rtcpu_vinotify_event: tstamp:3209373908 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3912614912 data:0x10000000
kworker/0:2-992 [000] … 91.934718: rtcpu_vinotify_event: tstamp:3209374043 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3912644640 data:0x31000006
kworker/0:2-992 [000] … 91.934719: rtcpu_vinotify_event: tstamp:3209374201 tag:FS channel:0x00 frame:0 vi_tstamp:3209367931 data:0x00000015
kworker/0:2-992 [000] … 91.934720: rtcpu_vinotify_event: tstamp:3209374343 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3209367934 data:0x00000000
kworker/0:2-992 [000] … 91.934727: rtcpu_vinotify_error: tstamp:3209698130 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3209695305 data:0x000003c9
kworker/0:2-992 [000] … 91.934729: rtcpu_vinotify_event: tstamp:3209901705 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3209369144 data:0x00000001
kworker/0:2-992 [000] … 91.934730: rtcpu_vinotify_event: tstamp:3209901845 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3915584576 data:0x08020005
kworker/0:2-992 [000] … 91.934731: rtcpu_vinotify_event: tstamp:3209902022 tag:FE channel:0x01 frame:0 vi_tstamp:3209596110 data:0x00000025
kworker/0:2-992 [000] … 91.934732: rtcpu_vinotify_event: tstamp:3209902159 tag:FS channel:0x01 frame:0 vi_tstamp:3209694094 data:0x00000015
kworker/0:2-992 [000] … 91.934733: rtcpu_vinotify_event: tstamp:3209902317 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3209695305 data:0x000003c9
kworker/0:2-992 [000] … 91.934735: rtos_queue_send_from_isr_failed: tstamp:3210705143 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.934759: rtos_queue_send_from_isr_failed: tstamp:3210705296 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.934760: rtos_queue_send_from_isr_failed: tstamp:3210705447 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.934761: rtos_queue_send_from_isr_failed: tstamp:3210705595 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.934762: rtos_queue_send_from_isr_failed: tstamp:3210705742 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.934763: rtcpu_vinotify_event: tstamp:3210793283 tag:FE channel:0x00 frame:0 vi_tstamp:3210690090 data:0x00000025
kworker/0:2-992 [000] … 91.934765: rtcpu_vinotify_event: tstamp:3210793445 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3210690090 data:0x01000000
kworker/0:2-992 [000] … 91.934766: rtcpu_vinotify_event: tstamp:3210793585 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3957852736 data:0x01020005
kworker/0:2-992 [000] … 91.934767: rtcpu_vinotify_event: tstamp:3210793749 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3210690093 data:0x00000000
kworker/0:2-992 [000] … 91.934768: rtcpu_vinotify_event: tstamp:3210793886 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3957885600 data:0x07020006
kworker/0:2-992 [000] … 91.934769: rtcpu_vinotify_event: tstamp:3210794043 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3958067040 data:0x10000000
kworker/0:2-992 [000] … 91.934770: rtcpu_vinotify_event: tstamp:3210794175 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:3958096768 data:0x31000007
kworker/0:2-992 [000] … 91.934771: rtcpu_vinotify_event: tstamp:3210794339 tag:FS channel:0x00 frame:0 vi_tstamp:3210788274 data:0x00000015
kworker/0:2-992 [000] … 91.934772: rtcpu_vinotify_event: tstamp:3210794479 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3210788277 data:0x00000000
kworker/0:2-992 [000] … 91.934774: rtcpu_vinotify_event: tstamp:3210794636 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3210789487 data:0x00000001
kworker/0:2-992 [000] … 91.934775: rtcpu_vinotify_event: tstamp:3210794771 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3961020000 data:0x08020006
vi-output, imx1-8173 [001] … 91.969904: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 1, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 91.969907: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 1, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 91.990690: rtcpu_vinotify_error: tstamp:3211118473 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3211115646 data:0x000003c9
kworker/0:2-992 [000] … 91.990693: rtcpu_vinotify_event: tstamp:3211312597 tag:FE channel:0x01 frame:0 vi_tstamp:3211016453 data:0x00000025
kworker/0:2-992 [000] … 91.990695: rtcpu_vinotify_event: tstamp:3211312735 tag:FS channel:0x01 frame:0 vi_tstamp:3211114435 data:0x00000015
kworker/0:2-992 [000] … 91.990696: rtcpu_vinotify_event: tstamp:3211312894 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3211115646 data:0x000003c9
kworker/0:2-992 [000] … 91.990698: rtos_queue_send_from_isr_failed: tstamp:3212124432 queue:0x0bcb41f8
kworker/0:2-992 [000] … 91.990699: rtos_queue_send_from_isr_failed: tstamp:3212124602 queue:0x0bcb8a60
kworker/0:2-992 [000] … 91.990701: rtos_queue_send_from_isr_failed: tstamp:3212124752 queue:0x0bcba5e0
kworker/0:2-992 [000] … 91.990702: rtos_queue_send_from_isr_failed: tstamp:3212124900 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 91.990732: rtos_queue_send_from_isr_failed: tstamp:3212125047 queue:0x0bcbc160
kworker/0:2-992 [000] … 91.990740: rtos_queue_peek_from_isr_failed: tstamp:3212294048 queue:0x0bcbcf78
kworker/0:2-992 [000] … 91.990742: rtcpu_vinotify_event: tstamp:3212397180 tag:FE channel:0x00 frame:0 vi_tstamp:3212110431 data:0x00000025
kworker/0:2-992 [000] … 91.990743: rtcpu_vinotify_event: tstamp:3212397342 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3212110431 data:0x01000000
kworker/0:2-992 [000] … 91.990744: rtcpu_vinotify_event: tstamp:3212397483 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4003303648 data:0x01020006
kworker/0:2-992 [000] … 91.990746: rtcpu_vinotify_event: tstamp:3212397647 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3212110434 data:0x00000000
kworker/0:2-992 [000] … 91.990747: rtcpu_vinotify_event: tstamp:3212397785 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4003336512 data:0x07020007
kworker/0:2-992 [000] … 91.990748: rtcpu_vinotify_event: tstamp:3212397944 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4003523264 data:0x10000000
kworker/0:2-992 [000] … 91.990749: rtcpu_vinotify_event: tstamp:3212398080 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4003552960 data:0x31000008
kworker/0:2-992 [000] … 91.990750: rtcpu_vinotify_event: tstamp:3212398238 tag:FS channel:0x00 frame:0 vi_tstamp:3212208617 data:0x00000015
kworker/0:2-992 [000] … 91.990751: rtcpu_vinotify_event: tstamp:3212398378 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3212208619 data:0x00000000
kworker/0:2-992 [000] … 91.990753: rtcpu_vinotify_event: tstamp:3212398535 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3212209828 data:0x00000001
kworker/0:2-992 [000] … 91.990754: rtcpu_vinotify_event: tstamp:3212398670 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4006470944 data:0x08020007
kworker/0:2-992 [000] … 91.990755: rtcpu_vinotify_event: tstamp:3212538943 tag:FE channel:0x01 frame:0 vi_tstamp:3212436795 data:0x00000025
kworker/0:2-992 [000] … 91.990780: rtcpu_vinotify_event: tstamp:3212539078 tag:FS channel:0x01 frame:0 vi_tstamp:3212534775 data:0x00000015
kworker/0:2-992 [000] … 91.990781: rtcpu_vinotify_error: tstamp:3212540147 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3212535986 data:0x000003c9
vi-output, imx1-8173 [001] … 92.015365: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 92.015368: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 2, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.046678: rtcpu_vinotify_event: tstamp:3213048595 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3212535986 data:0x000003c9
kworker/0:2-992 [000] … 92.046682: rtos_queue_send_from_isr_failed: tstamp:3213545197 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.046684: rtos_queue_send_from_isr_failed: tstamp:3213545350 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.046685: rtos_queue_send_from_isr_failed: tstamp:3213545501 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.046686: rtos_queue_send_from_isr_failed: tstamp:3213545647 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.046687: rtos_queue_send_from_isr_failed: tstamp:3213545792 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.046688: rtcpu_vinotify_event: tstamp:3213591251 tag:FE channel:0x00 frame:0 vi_tstamp:3213530772 data:0x00000025
kworker/0:2-992 [000] … 92.046689: rtcpu_vinotify_event: tstamp:3213591412 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3213530772 data:0x01000000
kworker/0:2-992 [000] … 92.046691: rtcpu_vinotify_event: tstamp:3213591552 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4048754560 data:0x01020007
kworker/0:2-992 [000] … 92.046692: rtcpu_vinotify_event: tstamp:3213591714 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3213530775 data:0x00000000
kworker/0:2-992 [000] … 92.046693: rtcpu_vinotify_event: tstamp:3213591853 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4048787424 data:0x07020008
kworker/0:2-992 [000] … 92.046694: rtcpu_vinotify_event: tstamp:3213592010 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4048961024 data:0x10000000
kworker/0:2-992 [000] … 92.046695: rtcpu_vinotify_event: tstamp:3213592145 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4048990784 data:0x31000009
kworker/0:2-992 [000] … 92.046732: rtcpu_vinotify_error: tstamp:3213959147 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3213956327 data:0x000003c9
kworker/0:2-992 [000] … 92.046733: rtcpu_vinotify_event: tstamp:3214133506 tag:FS channel:0x00 frame:0 vi_tstamp:3213628959 data:0x00000015
kworker/0:2-992 [000] … 92.046735: rtcpu_vinotify_event: tstamp:3214133650 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3213628962 data:0x00000000
kworker/0:2-992 [000] … 92.046736: rtcpu_vinotify_event: tstamp:3214133811 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3213630171 data:0x00000001
kworker/0:2-992 [000] … 92.046737: rtcpu_vinotify_event: tstamp:3214133951 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4051921920 data:0x08020008
kworker/0:2-992 [000] … 92.046738: rtcpu_vinotify_event: tstamp:3214134107 tag:FE channel:0x01 frame:0 vi_tstamp:3213857137 data:0x00000025
kworker/0:2-992 [000] … 92.046739: rtcpu_vinotify_event: tstamp:3214134242 tag:FS channel:0x01 frame:0 vi_tstamp:3213955116 data:0x00000015
kworker/0:2-992 [000] … 92.046740: rtcpu_vinotify_event: tstamp:3214134398 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3213956327 data:0x000003c9
vi-output, imx1-8173 [001] … 92.060869: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 3, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 92.060872: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.102676: rtcpu_vinotify_event: tstamp:3214956114 tag:FE channel:0x00 frame:0 vi_tstamp:3214951112 data:0x00000025
kworker/0:2-992 [000] … 92.102680: rtos_queue_send_from_isr_failed: tstamp:3214967119 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.102681: rtos_queue_send_from_isr_failed: tstamp:3214967272 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.102682: rtos_queue_send_from_isr_failed: tstamp:3214967426 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.102713: rtos_queue_send_from_isr_failed: tstamp:3214967574 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.102714: rtos_queue_send_from_isr_failed: tstamp:3214967722 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.102721: rtcpu_vinotify_error: tstamp:3215379493 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3215376668 data:0x000003c9
kworker/0:2-992 [000] … 92.102723: rtcpu_vinotify_event: tstamp:3215489633 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3214951113 data:0x01000000
kworker/0:2-992 [000] … 92.102724: rtcpu_vinotify_event: tstamp:3215489775 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4094211392 data:0x01020008
kworker/0:2-992 [000] … 92.102725: rtcpu_vinotify_event: tstamp:3215489940 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3214951115 data:0x00000000
kworker/0:2-992 [000] … 92.102726: rtcpu_vinotify_event: tstamp:3215490079 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4094244896 data:0x07020009
kworker/0:2-992 [000] … 92.102728: rtcpu_vinotify_event: tstamp:3215490236 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4094458048 data:0x10000000
kworker/0:2-992 [000] … 92.102729: rtcpu_vinotify_event: tstamp:3215490371 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4094487712 data:0x3100000a
kworker/0:2-992 [000] … 92.102730: rtcpu_vinotify_event: tstamp:3215490528 tag:FS channel:0x00 frame:0 vi_tstamp:3215049302 data:0x00000015
kworker/0:2-992 [000] … 92.102731: rtcpu_vinotify_event: tstamp:3215490669 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3215049304 data:0x00000000
kworker/0:2-992 [000] … 92.102732: rtcpu_vinotify_event: tstamp:3215490830 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3215050514 data:0x00000001
kworker/0:2-992 [000] … 92.102733: rtcpu_vinotify_event: tstamp:3215490964 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4097372896 data:0x08020009
kworker/0:2-992 [000] … 92.102734: rtcpu_vinotify_event: tstamp:3215491119 tag:FE channel:0x01 frame:0 vi_tstamp:3215277480 data:0x00000025
kworker/0:2-992 [000] … 92.102763: rtcpu_vinotify_event: tstamp:3215491254 tag:FS channel:0x01 frame:0 vi_tstamp:3215375456 data:0x00000015
kworker/0:2-992 [000] … 92.102765: rtcpu_vinotify_event: tstamp:3215491407 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3215376668 data:0x000003c9
vi-output, imx1-8173 [001] … 92.106312: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 92.106315: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 0, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 92.151831: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 1, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [001] … 92.151834: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 1, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.158681: rtcpu_vinotify_event: tstamp:3216376495 tag:FE channel:0x00 frame:0 vi_tstamp:3216371453 data:0x00000025
kworker/0:2-992 [000] … 92.158684: rtcpu_vinotify_event: tstamp:3216376662 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3216371454 data:0x01000000
kworker/0:2-992 [000] … 92.158686: rtcpu_vinotify_event: tstamp:3216376804 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4139656352 data:0x01020009
kworker/0:2-992 [000] … 92.158688: rtos_queue_send_from_isr_failed: tstamp:3216387247 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.158689: rtos_queue_send_from_isr_failed: tstamp:3216387400 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.158690: rtos_queue_send_from_isr_failed: tstamp:3216387553 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.158691: rtos_queue_send_from_isr_failed: tstamp:3216387700 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.158693: rtos_queue_send_from_isr_failed: tstamp:3216387846 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.158700: rtcpu_vinotify_error: tstamp:3216799832 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3216797008 data:0x000003c9
kworker/0:2-992 [000] … 92.158701: rtcpu_vinotify_event: tstamp:3216900559 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3216371455 data:0x00000000
kworker/0:2-992 [000] … 92.158702: rtcpu_vinotify_event: tstamp:3216900702 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4139695808 data:0x0702000a
kworker/0:2-992 [000] … 92.158704: rtcpu_vinotify_event: tstamp:3216900866 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4139914432 data:0x10000000
kworker/0:2-992 [000] … 92.158732: rtcpu_vinotify_event: tstamp:3216901004 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4139944160 data:0x3100000b
kworker/0:2-992 [000] … 92.158734: rtcpu_vinotify_event: tstamp:3216901162 tag:FS channel:0x00 frame:0 vi_tstamp:3216469644 data:0x00000015
kworker/0:2-992 [000] … 92.158735: rtcpu_vinotify_event: tstamp:3216901303 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3216469647 data:0x00000000
kworker/0:2-992 [000] … 92.158736: rtcpu_vinotify_event: tstamp:3216901460 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3216470857 data:0x00000001
kworker/0:2-992 [000] … 92.158737: rtcpu_vinotify_event: tstamp:3216901595 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4142823904 data:0x0802000a
kworker/0:2-992 [000] … 92.158738: rtcpu_vinotify_event: tstamp:3216901749 tag:FE channel:0x01 frame:0 vi_tstamp:3216697822 data:0x00000025
kworker/0:2-992 [000] … 92.158740: rtcpu_vinotify_event: tstamp:3216901884 tag:FS channel:0x01 frame:0 vi_tstamp:3216795796 data:0x00000015
kworker/0:2-992 [000] … 92.158741: rtcpu_vinotify_event: tstamp:3216902037 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3216797008 data:0x000003c9
kworker/0:2-992 [000] … 92.158743: rtos_queue_peek_from_isr_failed: tstamp:3217294048 queue:0x0bcbcf78
kworker/0:2-992 [000] … 92.158744: rtcpu_vinotify_event: tstamp:3217796792 tag:FE channel:0x00 frame:0 vi_tstamp:3217791792 data:0x00000025
kworker/0:2-992 [000] … 92.158745: rtcpu_vinotify_event: tstamp:3217796956 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3217791793 data:0x01000000
kworker/0:2-992 [000] … 92.158747: rtcpu_vinotify_event: tstamp:3217797096 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4185107200 data:0x0102000a
kworker/0:2-992 [000] … 92.158748: rtcpu_vinotify_event: tstamp:3217797258 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3217791795 data:0x00000000
kworker/0:2-992 [000] … 92.158749: rtcpu_vinotify_event: tstamp:3217797395 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4185140064 data:0x0702000b
kworker/0:2-992 [000] … 92.158750: rtos_queue_send_from_isr_failed: tstamp:3217809647 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.158751: rtos_queue_send_from_isr_failed: tstamp:3217809799 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.158752: rtos_queue_send_from_isr_failed: tstamp:3217809952 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.158754: rtos_queue_send_from_isr_failed: tstamp:3217810099 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.158755: rtos_queue_send_from_isr_failed: tstamp:3217810245 queue:0x0bcbc160
vi-output, imx1-8173 [000] … 92.197171: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.197201: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 2, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.214709: rtcpu_vinotify_error: tstamp:3218220215 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3218217349 data:0x000003c9
kworker/0:2-992 [000] … 92.214712: rtcpu_vinotify_event: tstamp:3218311425 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4185397248 data:0x10000000
kworker/0:2-992 [000] … 92.214714: rtcpu_vinotify_event: tstamp:3218311569 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4185426944 data:0x3100000c
kworker/0:2-992 [000] … 92.214715: rtcpu_vinotify_event: tstamp:3218311731 tag:FS channel:0x00 frame:0 vi_tstamp:3217889986 data:0x00000015
kworker/0:2-992 [000] … 92.214716: rtcpu_vinotify_event: tstamp:3218311875 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3217889990 data:0x00000000
kworker/0:2-992 [000] … 92.214717: rtcpu_vinotify_event: tstamp:3218312035 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3217891199 data:0x00000001
kworker/0:2-992 [000] … 92.214719: rtcpu_vinotify_event: tstamp:3218312173 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4188274848 data:0x0802000b
kworker/0:2-992 [000] … 92.214720: rtcpu_vinotify_event: tstamp:3218312329 tag:FE channel:0x01 frame:0 vi_tstamp:3218118166 data:0x00000025
kworker/0:2-992 [000] … 92.214721: rtcpu_vinotify_event: tstamp:3218312463 tag:FS channel:0x01 frame:0 vi_tstamp:3218216136 data:0x00000015
kworker/0:2-992 [000] … 92.214722: rtcpu_vinotify_event: tstamp:3218312618 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3218217349 data:0x000003c9
kworker/0:2-992 [000] … 92.214723: rtcpu_vinotify_event: tstamp:3219223113 tag:FE channel:0x00 frame:0 vi_tstamp:3219212132 data:0x00000025
kworker/0:2-992 [000] … 92.214726: rtcpu_vinotify_event: tstamp:3219223276 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3219212133 data:0x01000000
kworker/0:2-992 [000] … 92.214727: rtcpu_vinotify_event: tstamp:3219223417 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4230558176 data:0x0102000b
kworker/0:2-992 [000] … 92.214728: rtcpu_vinotify_event: tstamp:3219223578 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3219212136 data:0x00000000
kworker/0:2-992 [000] … 92.214729: rtcpu_vinotify_event: tstamp:3219223716 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4230591040 data:0x0702000c
kworker/0:2-992 [000] … 92.214730: rtcpu_vinotify_event: tstamp:3219223873 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4230786752 data:0x10000000
kworker/0:2-992 [000] … 92.214731: rtcpu_vinotify_event: tstamp:3219224008 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4230816480 data:0x3100000d
kworker/0:2-992 [000] … 92.214733: rtos_queue_send_from_isr_failed: tstamp:3219227696 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.214735: rtos_queue_send_from_isr_failed: tstamp:3219227849 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.214736: rtos_queue_send_from_isr_failed: tstamp:3219228001 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.214737: rtos_queue_send_from_isr_failed: tstamp:3219228150 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.214738: rtos_queue_send_from_isr_failed: tstamp:3219228296 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.214745: rtcpu_vinotify_error: tstamp:3219640508 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3219637689 data:0x000003c9
kworker/0:2-992 [000] … 92.214746: rtcpu_vinotify_event: tstamp:3219721465 tag:FS channel:0x00 frame:0 vi_tstamp:3219310330 data:0x00000015
kworker/0:2-992 [000] … 92.214748: rtcpu_vinotify_event: tstamp:3219721612 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3219310332 data:0x00000000
kworker/0:2-992 [000] … 92.214749: rtcpu_vinotify_event: tstamp:3219721774 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3219311542 data:0x00000001
kworker/0:2-992 [000] … 92.214750: rtcpu_vinotify_event: tstamp:3219721911 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4233725760 data:0x0802000c
kworker/0:2-992 [000] … 92.214751: rtcpu_vinotify_event: tstamp:3219722070 tag:FE channel:0x01 frame:0 vi_tstamp:3219538508 data:0x00000025
kworker/0:2-992 [000] … 92.214752: rtcpu_vinotify_event: tstamp:3219722206 tag:FS channel:0x01 frame:0 vi_tstamp:3219636477 data:0x00000015
kworker/0:2-992 [000] … 92.214753: rtcpu_vinotify_event: tstamp:3219722361 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3219637689 data:0x000003c9
vi-output, imx1-8173 [000] … 92.242691: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 3, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.242695: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.270671: rtos_queue_send_from_isr_failed: tstamp:3220649822 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.270674: rtos_queue_send_from_isr_failed: tstamp:3220649976 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.270676: rtos_queue_send_from_isr_failed: tstamp:3220650129 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.270677: rtos_queue_send_from_isr_failed: tstamp:3220650276 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.270678: rtos_queue_send_from_isr_failed: tstamp:3220650423 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.270680: rtcpu_vinotify_event: tstamp:3220735888 tag:FE channel:0x00 frame:0 vi_tstamp:3220632474 data:0x00000025
kworker/0:2-992 [000] … 92.270681: rtcpu_vinotify_event: tstamp:3220736066 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3220632475 data:0x01000000
kworker/0:2-992 [000] … 92.270709: rtcpu_vinotify_event: tstamp:3220736206 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4276009056 data:0x0102000c
kworker/0:2-992 [000] … 92.270710: rtcpu_vinotify_event: tstamp:3220736368 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3220632477 data:0x00000000
kworker/0:2-992 [000] … 92.270711: rtcpu_vinotify_event: tstamp:3220736508 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4276041920 data:0x0702000d
kworker/0:2-992 [000] … 92.270712: rtcpu_vinotify_event: tstamp:3220736666 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4276215232 data:0x10000000
kworker/0:2-992 [000] … 92.270713: rtcpu_vinotify_event: tstamp:3220736801 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4276244960 data:0x3100000e
kworker/0:2-992 [000] … 92.270715: rtcpu_vinotify_event: tstamp:3220736962 tag:FS channel:0x00 frame:0 vi_tstamp:3220730672 data:0x00000015
kworker/0:2-992 [000] … 92.270716: rtcpu_vinotify_event: tstamp:3220737102 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3220730675 data:0x00000000
kworker/0:2-992 [000] … 92.270723: rtcpu_vinotify_error: tstamp:3221060853 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3221058028 data:0x000003c9
kworker/0:2-992 [000] … 92.270724: rtcpu_vinotify_event: tstamp:3221240997 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3220731884 data:0x00000001
kworker/0:2-992 [000] … 92.270725: rtcpu_vinotify_event: tstamp:3221241136 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4279192320 data:0x0802000d
kworker/0:2-992 [000] … 92.270726: rtcpu_vinotify_event: tstamp:3221241294 tag:FE channel:0x01 frame:0 vi_tstamp:3220958851 data:0x00000025
kworker/0:2-992 [000] … 92.270728: rtcpu_vinotify_event: tstamp:3221241429 tag:FS channel:0x01 frame:0 vi_tstamp:3221056817 data:0x00000015
kworker/0:2-992 [000] … 92.270753: rtcpu_vinotify_event: tstamp:3221241586 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3221058028 data:0x000003c9
vi-output, imx1-8173 [000] … 92.288107: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.288110: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 0, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.326666: rtos_queue_send_from_isr_failed: tstamp:3222068418 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.326670: rtos_queue_send_from_isr_failed: tstamp:3222068575 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.326671: rtos_queue_send_from_isr_failed: tstamp:3222068728 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.326672: rtos_queue_send_from_isr_failed: tstamp:3222068875 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.326673: rtos_queue_send_from_isr_failed: tstamp:3222069021 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.326675: rtcpu_vinotify_event: tstamp:3222156028 tag:FE channel:0x00 frame:0 vi_tstamp:3222052813 data:0x00000025
kworker/0:2-992 [000] … 92.326677: rtcpu_vinotify_event: tstamp:3222156207 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3222052813 data:0x01000000
kworker/0:2-992 [000] … 92.326678: rtcpu_vinotify_event: tstamp:3222156351 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4321459904 data:0x0102000d
kworker/0:2-992 [000] … 92.326679: rtcpu_vinotify_event: tstamp:3222156515 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3222052816 data:0x00000000
kworker/0:2-992 [000] … 92.326680: rtcpu_vinotify_event: tstamp:3222156656 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4321492736 data:0x0702000e
kworker/0:2-992 [000] … 92.326681: rtcpu_vinotify_event: tstamp:3222156814 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4321677088 data:0x10000000
kworker/0:2-992 [000] … 92.326682: rtcpu_vinotify_event: tstamp:3222156949 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4321706784 data:0x3100000f
kworker/0:2-992 [000] … 92.326709: rtcpu_vinotify_event: tstamp:3222157107 tag:FS channel:0x00 frame:0 vi_tstamp:3222151015 data:0x00000015
kworker/0:2-992 [000] … 92.326711: rtcpu_vinotify_event: tstamp:3222157246 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3222151018 data:0x00000000
kworker/0:2-992 [000] … 92.326712: rtcpu_vinotify_event: tstamp:3222157448 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3222152228 data:0x00000001
kworker/0:2-992 [000] … 92.326713: rtcpu_vinotify_event: tstamp:3222157583 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4324627712 data:0x0802000e
kworker/0:2-992 [000] … 92.326721: rtos_queue_peek_from_isr_failed: tstamp:3222294048 queue:0x0bcbcf78
kworker/0:2-992 [000] … 92.326723: rtcpu_vinotify_error: tstamp:3222481189 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3222478369 data:0x000003c9
kworker/0:2-992 [000] … 92.326724: rtcpu_vinotify_event: tstamp:3222651895 tag:FE channel:0x01 frame:0 vi_tstamp:3222379194 data:0x00000025
kworker/0:2-992 [000] … 92.326726: rtcpu_vinotify_event: tstamp:3222652033 tag:FS channel:0x01 frame:0 vi_tstamp:3222477158 data:0x00000015
kworker/0:2-992 [000] … 92.326727: rtcpu_vinotify_event: tstamp:3222652190 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3222478369 data:0x000003c9
vi-output, imx1-8173 [000] … 92.333565: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 1, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.333573: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 1, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.378955: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.378958: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 2, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.382697: rtos_queue_send_from_isr_failed: tstamp:3223488824 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.382700: rtos_queue_send_from_isr_failed: tstamp:3223488977 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.382701: rtos_queue_send_from_isr_failed: tstamp:3223489130 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.382702: rtos_queue_send_from_isr_failed: tstamp:3223489278 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.382703: rtos_queue_send_from_isr_failed: tstamp:3223489423 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.382711: rtcpu_vinotify_event: tstamp:3223736473 tag:FE channel:0x00 frame:0 vi_tstamp:3223473153 data:0x00000025
kworker/0:2-992 [000] … 92.382712: rtcpu_vinotify_event: tstamp:3223736635 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3223473154 data:0x01000000
kworker/0:2-992 [000] … 92.382713: rtcpu_vinotify_event: tstamp:3223736778 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4366910784 data:0x0102000e
kworker/0:2-992 [000] … 92.382715: rtcpu_vinotify_event: tstamp:3223736941 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3223473155 data:0x00000000
kworker/0:2-992 [000] … 92.382716: rtcpu_vinotify_event: tstamp:3223737080 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4366943616 data:0x0702000f
kworker/0:2-992 [000] … 92.382717: rtcpu_vinotify_event: tstamp:3223737237 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4367133216 data:0x10000000
kworker/0:2-992 [000] … 92.382718: rtcpu_vinotify_event: tstamp:3223737372 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4367162944 data:0x31000010
kworker/0:2-992 [000] … 92.382719: rtcpu_vinotify_event: tstamp:3223737529 tag:FS channel:0x00 frame:0 vi_tstamp:3223571358 data:0x00000015
kworker/0:2-992 [000] … 92.382720: rtcpu_vinotify_event: tstamp:3223737670 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3223571361 data:0x00000000
kworker/0:2-992 [000] … 92.382721: rtcpu_vinotify_event: tstamp:3223737829 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3223572570 data:0x00000001
kworker/0:2-992 [000] … 92.382723: rtcpu_vinotify_event: tstamp:3223737966 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4370078656 data:0x0802000f
kworker/0:2-992 [000] … 92.382724: rtcpu_vinotify_event: tstamp:3223901670 tag:FE channel:0x01 frame:0 vi_tstamp:3223799536 data:0x00000025
kworker/0:2-992 [000] … 92.382725: rtcpu_vinotify_event: tstamp:3223901805 tag:FS channel:0x01 frame:0 vi_tstamp:3223897498 data:0x00000015
kworker/0:2-992 [000] … 92.382726: rtcpu_vinotify_error: tstamp:3223902892 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3223898709 data:0x000003c9
kworker/0:2-992 [000] … 92.382728: rtcpu_vinotify_event: tstamp:3224441873 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3223898709 data:0x000003c9
kworker/0:2-992 [000] … 92.382729: rtos_queue_send_from_isr_failed: tstamp:3224907469 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.382730: rtos_queue_send_from_isr_failed: tstamp:3224907622 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.382731: rtos_queue_send_from_isr_failed: tstamp:3224907774 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.382732: rtos_queue_send_from_isr_failed: tstamp:3224907920 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.382733: rtos_queue_send_from_isr_failed: tstamp:3224908065 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.382734: rtcpu_vinotify_event: tstamp:3224984528 tag:FE channel:0x00 frame:0 vi_tstamp:3224893495 data:0x00000025
kworker/0:2-992 [000] … 92.382736: rtcpu_vinotify_event: tstamp:3224984689 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3224893495 data:0x01000000
kworker/0:2-992 [000] … 92.382737: rtcpu_vinotify_event: tstamp:3224984830 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4412361696 data:0x0102000f
kworker/0:2-992 [000] … 92.382738: rtcpu_vinotify_event: tstamp:3224984991 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3224893498 data:0x00000000
kworker/0:2-992 [000] … 92.382739: rtcpu_vinotify_event: tstamp:3224985129 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4412394560 data:0x07020010
kworker/0:2-992 [000] … 92.382740: rtcpu_vinotify_event: tstamp:3224985287 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4412588384 data:0x10000000
kworker/0:2-992 [000] … 92.382741: rtcpu_vinotify_event: tstamp:3224985423 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4412618080 data:0x31000011
vi-output, imx1-8173 [000] … 92.424473: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 3, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.424477: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.438707: rtcpu_vinotify_error: tstamp:3225321873 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3225319050 data:0x000003c9
kworker/0:2-992 [000] … 92.438711: rtcpu_vinotify_event: tstamp:3225526784 tag:FS channel:0x00 frame:0 vi_tstamp:3224991700 data:0x00000015
kworker/0:2-992 [000] … 92.438712: rtcpu_vinotify_event: tstamp:3225526927 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3224991703 data:0x00000000
kworker/0:2-992 [000] … 92.438714: rtcpu_vinotify_event: tstamp:3225527089 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3224992912 data:0x00000001
kworker/0:2-992 [000] … 92.438715: rtcpu_vinotify_event: tstamp:3225527227 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4415529664 data:0x08020010
kworker/0:2-992 [000] … 92.438716: rtcpu_vinotify_event: tstamp:3225527383 tag:FE channel:0x01 frame:0 vi_tstamp:3225219879 data:0x00000025
kworker/0:2-992 [000] … 92.438717: rtcpu_vinotify_event: tstamp:3225527518 tag:FS channel:0x01 frame:0 vi_tstamp:3225317838 data:0x00000015
kworker/0:2-992 [000] … 92.438718: rtcpu_vinotify_event: tstamp:3225527674 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3225319050 data:0x000003c9
kworker/0:2-992 [000] … 92.438720: rtcpu_vinotify_event: tstamp:3226318833 tag:FE channel:0x00 frame:0 vi_tstamp:3226313834 data:0x00000025
kworker/0:2-992 [000] … 92.438722: rtos_queue_send_from_isr_failed: tstamp:3226329830 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.438723: rtos_queue_send_from_isr_failed: tstamp:3226329981 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.438724: rtos_queue_send_from_isr_failed: tstamp:3226330132 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.438726: rtos_queue_send_from_isr_failed: tstamp:3226330279 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.438727: rtos_queue_send_from_isr_failed: tstamp:3226330424 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.438732: rtcpu_vinotify_error: tstamp:3226742214 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3226739391 data:0x000003c9
vi-output, imx1-8173 [000] … 92.469923: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.469925: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 0, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.494657: rtcpu_vinotify_event: tstamp:3226828930 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3226313835 data:0x01000000
kworker/0:2-992 [000] … 92.494660: rtcpu_vinotify_event: tstamp:3226829082 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4457818496 data:0x01020010
kworker/0:2-992 [000] … 92.494662: rtcpu_vinotify_event: tstamp:3226829249 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3226313836 data:0x00000000
kworker/0:2-992 [000] … 92.494663: rtcpu_vinotify_event: tstamp:3226829391 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4457852000 data:0x07020011
kworker/0:2-992 [000] … 92.494664: rtcpu_vinotify_event: tstamp:3226829553 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4458059776 data:0x10000000
kworker/0:2-992 [000] … 92.494665: rtcpu_vinotify_event: tstamp:3226829689 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4458089536 data:0x31000012
kworker/0:2-992 [000] … 92.494666: rtcpu_vinotify_event: tstamp:3226829847 tag:FS channel:0x00 frame:0 vi_tstamp:3226412043 data:0x00000015
kworker/0:2-992 [000] … 92.494668: rtcpu_vinotify_event: tstamp:3226829987 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3226412045 data:0x00000000
kworker/0:2-992 [000] … 92.494669: rtcpu_vinotify_event: tstamp:3226830148 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3226413255 data:0x00000001
kworker/0:2-992 [000] … 92.494670: rtcpu_vinotify_event: tstamp:3226830284 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4460980640 data:0x08020011
kworker/0:2-992 [000] … 92.494671: rtcpu_vinotify_event: tstamp:3226830437 tag:FE channel:0x01 frame:0 vi_tstamp:3226640221 data:0x00000025
kworker/0:2-992 [000] … 92.494672: rtcpu_vinotify_event: tstamp:3226830572 tag:FS channel:0x01 frame:0 vi_tstamp:3226738179 data:0x00000015
kworker/0:2-992 [000] … 92.494673: rtcpu_vinotify_event: tstamp:3226830726 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3226739391 data:0x000003c9
kworker/0:2-992 [000] … 92.494676: rtos_queue_peek_from_isr_failed: tstamp:3227294051 queue:0x0bcbcf78
kworker/0:2-992 [000] … 92.494677: rtcpu_vinotify_event: tstamp:3227739174 tag:FE channel:0x00 frame:0 vi_tstamp:3227734175 data:0x00000025
kworker/0:2-992 [000] … 92.494678: rtcpu_vinotify_event: tstamp:3227739339 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3227734176 data:0x01000000
kworker/0:2-992 [000] … 92.494679: rtcpu_vinotify_event: tstamp:3227739480 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4503263488 data:0x01020011
kworker/0:2-992 [000] … 92.494681: rtos_queue_send_from_isr_failed: tstamp:3227750131 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.494682: rtos_queue_send_from_isr_failed: tstamp:3227750283 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.494683: rtos_queue_send_from_isr_failed: tstamp:3227750435 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.494685: rtos_queue_send_from_isr_failed: tstamp:3227750582 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.494686: rtos_queue_send_from_isr_failed: tstamp:3227750729 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.494693: rtcpu_vinotify_error: tstamp:3228162552 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3228159731 data:0x000003c9
kworker/0:2-992 [000] … 92.494694: rtcpu_vinotify_event: tstamp:3228239834 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3227734177 data:0x00000000
kworker/0:2-992 [000] … 92.494696: rtcpu_vinotify_event: tstamp:3228239978 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4503302848 data:0x07020012
kworker/0:2-992 [000] … 92.494697: rtcpu_vinotify_event: tstamp:3228240140 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4503541888 data:0x10000000
kworker/0:2-992 [000] … 92.494698: rtcpu_vinotify_event: tstamp:3228240276 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4503571616 data:0x31000013
kworker/0:2-992 [000] … 92.494699: rtcpu_vinotify_event: tstamp:3228240433 tag:FS channel:0x00 frame:0 vi_tstamp:3227832385 data:0x00000015
kworker/0:2-992 [000] … 92.494700: rtcpu_vinotify_event: tstamp:3228240573 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3227832388 data:0x00000000
kworker/0:2-992 [000] … 92.494701: rtcpu_vinotify_event: tstamp:3228240734 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3227833597 data:0x00000001
kworker/0:2-992 [000] … 92.494702: rtcpu_vinotify_event: tstamp:3228240869 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4506431584 data:0x08020012
kworker/0:2-992 [000] … 92.494704: rtcpu_vinotify_event: tstamp:3228241023 tag:FE channel:0x01 frame:0 vi_tstamp:3228060563 data:0x00000025
kworker/0:2-992 [000] … 92.494705: rtcpu_vinotify_event: tstamp:3228241158 tag:FS channel:0x01 frame:0 vi_tstamp:3228158519 data:0x00000015
kworker/0:2-992 [000] … 92.494706: rtcpu_vinotify_event: tstamp:3228241312 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3228159731 data:0x000003c9
vi-output, imx1-8173 [000] … 92.515384: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 1, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.515387: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 1, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.550674: rtcpu_vinotify_event: tstamp:3229159553 tag:FE channel:0x00 frame:0 vi_tstamp:3229154515 data:0x00000025
kworker/0:2-992 [000] … 92.550677: rtcpu_vinotify_event: tstamp:3229159719 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3229154516 data:0x01000000
kworker/0:2-992 [000] … 92.550679: rtcpu_vinotify_event: tstamp:3229159861 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4548714368 data:0x01020012
kworker/0:2-992 [000] … 92.550680: rtcpu_vinotify_event: tstamp:3229160023 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3229154518 data:0x00000000
kworker/0:2-992 [000] … 92.550681: rtcpu_vinotify_event: tstamp:3229160162 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4548747232 data:0x07020013
kworker/0:2-992 [000] … 92.550683: rtos_queue_send_from_isr_failed: tstamp:3229170713 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.550715: rtos_queue_send_from_isr_failed: tstamp:3229170883 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.550716: rtos_queue_send_from_isr_failed: tstamp:3229171036 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.550717: rtos_queue_send_from_isr_failed: tstamp:3229171184 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.550718: rtos_queue_send_from_isr_failed: tstamp:3229171329 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.550725: rtcpu_vinotify_error: tstamp:3229582893 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3229580072 data:0x000003c9
kworker/0:2-992 [000] … 92.550726: rtcpu_vinotify_event: tstamp:3229649905 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4548981120 data:0x10000000
kworker/0:2-992 [000] … 92.550727: rtcpu_vinotify_event: tstamp:3229650048 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4549010816 data:0x31000014
kworker/0:2-992 [000] … 92.550729: rtcpu_vinotify_event: tstamp:3229650208 tag:FS channel:0x00 frame:0 vi_tstamp:3229252728 data:0x00000015
kworker/0:2-992 [000] … 92.550730: rtcpu_vinotify_event: tstamp:3229650353 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3229252730 data:0x00000000
kworker/0:2-992 [000] … 92.550731: rtcpu_vinotify_event: tstamp:3229650514 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3229253941 data:0x00000001
kworker/0:2-992 [000] … 92.550732: rtcpu_vinotify_event: tstamp:3229650651 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4551882528 data:0x08020013
kworker/0:2-992 [000] … 92.550733: rtcpu_vinotify_event: tstamp:3229650805 tag:FE channel:0x01 frame:0 vi_tstamp:3229480907 data:0x00000025
kworker/0:2-992 [000] … 92.550761: rtcpu_vinotify_event: tstamp:3229650940 tag:FS channel:0x01 frame:0 vi_tstamp:3229578859 data:0x00000015
kworker/0:2-992 [000] … 92.550762: rtcpu_vinotify_event: tstamp:3229651096 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3229580072 data:0x000003c9
vi-output, imx1-8173 [000] … 92.560766: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.560769: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 2, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.606216: vb2_buf_done: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 3, index = 3, type = 1, bytesused = 4147200, timestamp = 0
vi-output, imx1-8173 [000] … 92.606219: vb2_buf_queue: owner = ffffffc1a5dc9a80, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 4147200, timestamp = 0
kworker/0:2-992 [000] … 92.606682: rtcpu_vinotify_event: tstamp:3230585104 tag:FE channel:0x00 frame:0 vi_tstamp:3230574856 data:0x00000025
kworker/0:2-992 [000] … 92.606684: rtcpu_vinotify_event: tstamp:3230585267 tag:CHANSEL_SHORT_FRAME channel:0x20 frame:0 vi_tstamp:3230574857 data:0x01000000
kworker/0:2-992 [000] … 92.606686: rtcpu_vinotify_event: tstamp:3230585406 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4594165280 data:0x01020013
kworker/0:2-992 [000] … 92.606687: rtcpu_vinotify_event: tstamp:3230585567 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3230574859 data:0x00000000
kworker/0:2-992 [000] … 92.606688: rtcpu_vinotify_event: tstamp:3230585704 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4594198112 data:0x07020014
kworker/0:2-992 [000] … 92.606689: rtcpu_vinotify_event: tstamp:3230585861 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4594370624 data:0x10000000
kworker/0:2-992 [000] … 92.606691: rtcpu_vinotify_event: tstamp:3230585996 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4594400320 data:0x31000015
kworker/0:2-992 [000] … 92.606693: rtos_queue_send_from_isr_failed: tstamp:3230588908 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.606694: rtos_queue_send_from_isr_failed: tstamp:3230589061 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.606695: rtos_queue_send_from_isr_failed: tstamp:3230589214 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.606697: rtos_queue_send_from_isr_failed: tstamp:3230589362 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.606698: rtos_queue_send_from_isr_failed: tstamp:3230589507 queue:0x0bcbc160
kworker/0:2-992 [000] … 92.606729: rtcpu_vinotify_error: tstamp:3231003238 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3231000412 data:0x000003c9
kworker/0:2-992 [000] … 92.606730: rtcpu_vinotify_event: tstamp:3231115546 tag:FS channel:0x00 frame:0 vi_tstamp:3230673071 data:0x00000015
kworker/0:2-992 [000] … 92.606731: rtcpu_vinotify_event: tstamp:3231115691 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3230673073 data:0x00000000
kworker/0:2-992 [000] … 92.606732: rtcpu_vinotify_event: tstamp:3231115857 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3230674283 data:0x00000001
kworker/0:2-992 [000] … 92.606734: rtcpu_vinotify_event: tstamp:3231115999 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4597333472 data:0x08020014
kworker/0:2-992 [000] … 92.606735: rtcpu_vinotify_event: tstamp:3231116155 tag:FE channel:0x01 frame:0 vi_tstamp:3230901249 data:0x00000025
kworker/0:2-992 [000] … 92.606736: rtcpu_vinotify_event: tstamp:3231116290 tag:FS channel:0x01 frame:0 vi_tstamp:3230999200 data:0x00000015
kworker/0:2-992 [000] … 92.606738: rtcpu_vinotify_event: tstamp:3231116446 tag:CHANSEL_NOMATCH channel:0x60 frame:0 vi_tstamp:3231000412 data:0x000003c9
kworker/0:2-992 [000] … 92.606740: rtos_queue_send_from_isr_failed: tstamp:3232009216 queue:0x0bcb41f8
kworker/0:2-992 [000] … 92.606741: rtos_queue_send_from_isr_failed: tstamp:3232009369 queue:0x0bcb8a60
kworker/0:2-992 [000] … 92.606742: rtos_queue_send_from_isr_failed: tstamp:3232009522 queue:0x0bcba5e0
kworker/0:2-992 [000] … 92.606743: rtos_queue_send_from_isr_failed: tstamp:3232009668 queue:0x0bcbb3a0
kworker/0:2-992 [000] … 92.606744: rtos_queue_send_from_isr_failed: tstamp:3232009813 queue:0x0bcbc160
The log show the CHANSEL_SHORT_FRAME that tell the sensor output size less than expect.
