So I am just following the tutorial here :
2. Create New Extension Project: Press “Plus” button on the top left
Visual studio code is not launching, so I am stuck as to what to do next.
I am adding the console lines pertaining to the problem, if it helps…
Seems like there is a problem with kit?
PS : tried launching omni.code.bat as administrator, it did change the console error.
Hi @aws357. Can you try running Code from the Launcher instead?
In the first part of the message, I have launched code from the launcher.
I only started dabbling with the .bat in administrator mode when I read the “symbolic link privilege not held”
ok, I solved the problem (it’s a very stupidly embarrassing one).
I was working on a folder that was on a cloud drive (pcloud) so my guess is that it didn’t play well with the python script link.py.
I made a folder on a “normal” hard drive and it seems to do the trick.
