WARNING: erroneous pipeline: no element "nvinfer" On nvcr.io/nvidia/deepstream:6.1-devel Docker
• Hardware Platform (Jetson / GPU) - GTX 1050 Ti
• NVIDIA GPU Driver Version (valid for GPU only) - 516.40
Hello, I am trying to run an application inside the nvcr.io/nvidia/deepstream:6.1-devel docker and I am getting the following error
nvidia-smi inside docker:
root@docker-desktop:/opt/nvidia/deepstream/deepstream-6.1# nvidia-smi
Sun Jun 26 15:28:04 2022
| NVIDIA-SMI 515.48.07    Driver Version: 516.40       CUDA Version: 11.7     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  On   | 00000000:01:00.0 Off |                  N/A |
| N/A   41C    P8    N/A /  N/A |      0MiB /  4096MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
nvidia-smi outside container
| NVIDIA-SMI 516.40       Driver Version: 516.40       CUDA Version: 11.7     |
| GPU  Name            TCC/WDDM | Bus-Id        Disp.A | Volatile Uncorr. ECC |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ... WDDM  | 00000000:01:00.0 Off |                  N/A |
|                               |                      |                  N/A |
| Processes:        |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      6664    C+G   ...2txyewy\TextInputHost.exe    N/A      |
|    0   N/A  N/A      7732    C+G   ...ontend\Docker Desktop.exe    N/A      |
|    0   N/A  N/A      8592    C+G   ...264.37\msedgewebview2.exe    N/A      |
|    0   N/A  N/A     12824    C+G   ...ram Files\LGHUB\lghub.exe    N/A      |
|    0   N/A  N/A     14316    C+G   ...icrosoft VS Code\Code.exe    N/A      |
|    0   N/A  N/A     15808    C+G   ...x64\LenovoNerveCenter.exe    N/A      |
|    0   N/A  N/A     16328    C+G   ...lack\app-4.26.2\slack.exe    N/A      |
|    0   N/A  N/A     21452    C+G   ...artMenuExperienceHost.exe    N/A      |
|    0   N/A  N/A     21924    C+G   ...n1h2txyewy\SearchHost.exe    N/A      |
|    0   N/A  N/A     22280    C+G   ...X2_APP\DolbyDAX2Toast.exe    N/A      |
|    0   N/A  N/A     23088    C+G   C:\Windows\System32\dwm.exe     N/A      |
When I run gst-inspect-1.0 libnvdsgst_infer.so i get he following output:
root@docker-desktop:/home/nvidia_test# gst-inspect-1.0 lib libnvdsgst_infer.so
Plugin Details:
  Name                     libnvdsgst_infer.so
  Description              Plugin for blacklisted file
  Filename                 /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so
  Version                  0.0.0
  License                  BLACKLIST
  Source module            BLACKLIST
  Binary package           BLACKLIST
  Origin URL               BLACKLIST
  0 features:
Can anyone tell me how to remove this error?
Looking forward to the replies !!
Please use NVIDIA driver 510.47.03 for Deepstream SDK 6.1
Hello @Amycao,
Thank you for the information. Do you have any container available which could work on NVIDIA driver version 516.40?
For deepstream container, we do not have which can run on driver version 516.40 by now.
Hello @Amycao,
Ok, no worries! Thanks for the information.
