I’m getting this
WARNING: GPU:0: Unable to read EDID for display device VGA-0
error with kernel parameter: nvidia-drm.modeset=1
~ ls /sys/class/drm
card0 card0-HDMI-A-1 card0-VGA-2 card1 card1-LVDS-1 card1-VGA-1 renderD128 renderD129 version
I tried to disable device with video=VGA-2:d and it didn’t show error until OS loaded.
~ xrandr -q
outputs VGA-0 is connected when it’s not. Disabling and ignoring with xorg.conf didn’t help.
Section "Monitor"
Identifier "VGA-0"
Option "Ignore" "true"
Option "Enable" "false"
EndSection
Driver Version: 390.48
Kernel: 4.15.0-36-generic
It’s a known issue with some bioses. The option
Option “IgnoreDisplayDevices” “CRT”
put into the screen or the device section of your xorg.conf should help, though a bug with that was observed before in a recent driver. Please check.
Sorry for delay, but your suggestion did not work for me. I’m still getting this error when session is locked and also on login screen. As I know, gpu-manager controls my xorg configs.
I’m using proprietary driver. Driver Version: 390.77
/var/log/gpu-manager.log
log_file: /var/log/gpu-manager.log
last_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
new_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
can't access /opt/amdgpu-pro/bin/amdgpu-pro-px
Looking for nvidia modules in /lib/modules/4.15.0-43-generic/updates/dkms
Found nvidia module: nvidia-drm.ko
Looking for amdgpu modules in /lib/modules/4.15.0-43-generic/updates/dkms
Is nvidia loaded? yes
Was nvidia unloaded? no
Is nvidia blacklisted? no
Is intel loaded? yes
Is radeon loaded? no
Is radeon blacklisted? no
Is amdgpu loaded? no
Is amdgpu blacklisted? no
Is amdgpu versioned? no
Is amdgpu pro stack? no
Is nouveau loaded? no
Is nouveau blacklisted? yes
Is nvidia kernel module available? yes
Is amdgpu kernel module available? no
Vendor/Device Id: 8086:116
BusID "PCI:0@0:2:0"
Is boot vga? yes
Vendor/Device Id: 10de:df5
BusID "PCI:1@0:0:0"
Is boot vga? no
Skipping "/dev/dri/card1", driven by "i915"
Skipping "/dev/dri/card0", driven by "nvidia-drm"
Found "/dev/dri/card1", driven by "i915"
output 0:
card1-LVDS-1
Number of connected outputs for /dev/dri/card1: 1
Does it require offloading? yes
last cards number = 2
Has amd? no
Has intel? yes
Has nvidia? yes
How many cards? 2
Has the system changed? No
Intel IGP detected
Intel hybrid system
Creating /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf
Setting power control to "on" in /sys/bus/pci/devices/0000:01:00.0/power/control
# DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
Section "OutputClass"
Identifier "Nvidia Prime"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
Option "IgnoreDisplayDevices" "CRT"
Option "PrimaryGPU" "Yes"
ModulePath "/x86_64-linux-gnu/nvidia/xorg"
EndSection
Please check if
xrandr --output VGA-0 --off
works for you.
Not working.
$ xrandr --output VGA-0 --off
warning: output VGA-0 not found; ignoring
I already disabled it in xorg.conf
/usr/share/X11/xorg.conf.d/80-disablevga.conf
Section "Monitor"
Identifier "VGA-0"
EndSection
$ xrandr -q
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 544mm x 303mm
1920x1080 60.00*+ 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
LVDS-1-1 connected (normal left inverted right x axis y axis)
1366x768 60.01 +
1360x768 59.80 59.96
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
VGA-1-1 disconnected (normal left inverted right x axis y axis)
1024x768 (0x4c) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x5b) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
640x480 (0x6a) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nvidia-drm.modeset=1 video=VGA-2:d"
I can’t see LUKS encryption password enter screen on my external monitor too. I think it’s something with driver because when I tried nouveau driver I could see password screen on external monitor. Forcing mode with kernel mode setting did not help.
I have the same problem for long time. The videocard remembers and persistently calls 2nd VGA monitor that was switched off years ago.
the appendix d says
The following driver options are supported by the NVIDIA X driver. They may be specified either in the Screen or Device sections of the X config file.
but you did use the OutputClass section.
btw I have the same issue. unable to solve it. did you find any further clues about the error message?
I think the error also causes some screen flickering when scrolling pages.
