Hey, I managed to bring in Alembic data to Composer!
Now I play with a rain drop material, but I cannot eliminate that black ring… Real Time RTX is preferred. Any ideas?
This looks like a case of not enough reflection bounces, so the spheres are showing up as black. I am assuming that in path tracing mode, this does not happen and it looks correct. This is easy to solve, you just need to increase the number of reflection bounces from “1”, which may be set by default, to a larger number like 4. Increase by +1 until desired result.
Hi!
Sorry this was not a solution:
and those black reflections are also in path traced more as you can see from the videos I have posted here.
Hey, on brass material this setting thing works!
So it turned out that the water material I had tweaked myself was somehow
strange…
I had problems with all water materials from library gave me just black surface.
I write a new topic about that.
