I have an RTX 3080 and having troubles with the NVIDIA driver in ubuntu 22.04. It is laggy, compared to previous ubuntu releases. There are issues with wayland, that block me from switching to.
Which driver is the recommended one for this setup? 515?
Workaround: Turning both vsync and page flipping off in the Nvidia Control Panel via nvidia-settings helps and reduces the performance drop, but it’s not an optimal solution bc now videos, webbrowsers and even games have lots of tearing.
@Sturmlocke Tried it, got a lot of tearing and didn’t really help much in the lagginess and excessive CPU load
For example when opening imgur.com, and trying to drag around the chrome window, the lag is visible.
When I try to drag a file manager on top of it, like nemo, the problem is even more exacerbated, the lag becomes unmanageable. This with or without your recommendation to switch vsync and page flipping off. I even tried playing around with Vulkan backend (enabled and disabled, in chrome://flags), but no difference as well.
