I’m trying to run a simple interactive code inside Isaac Sim to get the robot to move. However, I encounter the following error:
AttributeError: "WheeledRobot object has no attribute "_num_wheel_dof"
Code:
from omni.isaac.core.scenes import Scene
from omni.isaac.core.prims import XFormPrimView
from omni.isaac.core.utils.nucleus import get_assets_root_path
import omni.isaac.core.utils.stage as stage_utils
from omni.isaac.core.robots import Robot
from omni.isaac.wheeled_robots.robots import WheeledRobot
import numpy as np
from omni.isaac.core.utils.types import ArticulationAction
from omni.isaac.core.articulations import Articulation
assets_root_path = get_assets_root_path()
asset_path = assets_root_path + "/Isaac/Robots/Clearpath/Dingo/dingo.usd"
scene = Scene()
stage_utils.add_reference_to_stage(usd_path=asset_path, prim_path="/World/Fancy_Robot")
jetbot = scene.add(
WheeledRobot(
prim_path="/World/Fancy_Robot",
name="fancy_robot",
wheel_dof_names=["left_wheel_joint", "right_wheel_joint"],
create_robot=True,
action = ArticulationAction(joint_velocities = np.array([1.14, 1.42]))
jetbot.apply_wheel_actions(action)
Any help would be appreciated.
