Operating System:
[V] Windows
Linux
Kit Version:
107
106
105
Kit Template:
USD Composer
USD Explorer
USD Viewer
Custom
GPU Hardware:
A series (Blackwell)
A series (ADA)
A series
50 series
[V] 40 series
30 series
GPU Driver:
Latest
Recommended (573.xx)
[V] Other (560.94)
Main Issue:
When I create a cube and set viewport2,the isaac sim crashed
Error Code:
2025-05-16 01:59:17 [117,235ms] [Error] [gpu.foundation.plugin] A GPU crash occurred. Exiting the application…
Reasons for the failure: a device lost, out of memory, or an unexpected bug.
2025-05-16 01:59:17 [117,236ms] [Warning] [gpu.foundation.plugin] polling aftermath dump status …
2025-05-16 01:59:17 [117,401ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-0000023dbb11b190-00000230fab0d730.nvdbg
2025-05-16 01:59:17 [117,406ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-05-16 01:59:17 [117,407ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-0000023dbb11b190-0000023d6e15c500.nvdbg
2025-05-16 01:59:17 [117,410ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-05-16 01:59:17 [117,412ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-0000023dbb11b190-00000230fab0c4f0.nvdbg
2025-05-16 01:59:17 [117,416ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-05-16 01:59:17 [117,418ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-0000023dbb11b190-0000023dc72c21e0.nvdbg
2025-05-16 01:59:17 [117,459ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-05-16 01:59:17 [117,460ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-0000023dbb11b190-0000023dc72c4af0.nvdbg
2025-05-16 01:59:17 [117,464ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-05-16 01:59:17 [117,465ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-0000023dbb11b190-0000023da39008f0.nvdbg
2025-05-16 01:59:17 [117,469ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-05-16 01:59:17 [117,470ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-25f62cc0370e596c-0000023d8f5ecda0.nvdbg
2025-05-16 01:59:17 [117,472ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-05-16 01:59:17 [117,475ms] [Warning] [carb.graphics-vulkan.plugin] GPU pagefault occured on virtual address(0x000000000e610000)
2025-05-16 01:59:17 [117,475ms] [Warning] [carb.graphics-vulkan.plugin] GPU pagefault no associated data found closest allocations were:
2025-05-16 01:59:17 [117,475ms] [Warning] [carb.graphics-vulkan.plugin] 1: AddressRange(0x0000000000000000 - 0x0000000000000000) with name(dummy to ignore)
2025-05-16 01:59:17 [117,475ms] [Warning] [carb.graphics-vulkan.plugin] 2: AddressRange(0xffffffffffffffff - 0xffffffffffffffff) with name(dummy to ignore)
2025-05-16 01:59:17 [117,481ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-05-16 01:59:17 [117,482ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-05-16 01:59:17 [117,487ms] [Warning] [carb.graphics-vulkan.plugin] failed to find shader info with aftermath hash 0
2025-05-16 01:59:17 [117,488ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write crash dump into: C:/Users/user/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250516_095720-0.nv-gpudmp
2025-05-16 01:59:17 [117,491ms] [Error] [carb.graphics-vulkan.plugin] GPU crash dump is successfully written
2025-05-16 01:59:17 [117,587ms] [Warning] [gpu.foundation.plugin] successfully waited and produced aftermath dump
2025-05-16 01:59:19 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-05-16 01:59:19 [22ms] [Warning] [carb.crashreporter-breakpad.plugin] Launched process ‘py-spy.exe’ as PID 31324
2025-05-16 01:59:19 [310ms] [Error] [carb.crashreporter-breakpad.plugin] ‘py-spy.exe’ exited with code 1
2025-05-16 01:59:19 [318ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 11 files into ‘C:/Users/user/AppData/Local/ov/data/Kit/Isaac-Sim Full/4.5\34e6c1c6-246c-4d56-b09d-9e9883a8a15f.dmp.zip’ for upload.
2025-05-16 01:59:20 [1,363ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘C:/Users/user/AppData/Local/ov/data/Kit/Isaac-Sim Full/4.5\34e6c1c6-246c-4d56-b09d-9e9883a8a15f.dmp’ with 10 retries remaining.
2025-05-16 01:59:20 [1,366ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘C:/Users/user/AppData/Local/ov/data/Kit/Isaac-Sim Full/4.5\34e6c1c6-246c-4d56-b09d-9e9883a8a15f.dmp.toml’ with 10 retries remaining.
2025-05-16 01:59:20 [1,380ms] [Warning] [carb.crashreporter-breakpad.plugin] Launched process ‘crashreport.gui.exe’ as PID 37176
