As described in the title, I have never done anything similar to resetting the system before. Is it my short circuit fault that led to what mode? This is my current desktop and version number
Are you using nano 4gb or nano 2gb?
Since Ubuntu is a “flavor”/“distribution” of Linux, perhaps it was just a change in the software which populates that file. What do you see from “cat /etc/issue”? If you have other software which depends on “/proc/version” saying Ubuntu I imagine that could be a problem, but normally it won’t matter.
I’ll try it, because I’ve been used to using Ubuntu for a long time, and I’m not used to suddenly changing my style
4gb
Keep in mind that this is Ubuntu, but that’s just one distributor of Linux. You may have found it says just “Linux” somewhere, but all Ubuntu is Linux. It’s probably not changed, but is likely instead just not giving you the distribution name.
So what do I need to do to restore to the original Ubuntu branch
free -m
What is the result from this command?
The result is this, but I think the memory space should have nothing to do with this
I won’t just ask you to check the memory for no reason.
Please refer to /etc/systemd/nvfb-early.sh on your nano. Change the default display manger to gdm3 and do re-configure.
# Read total memory size in megabyte
TOTAL_MEM=$(free --mega | awk '/^Mem:/{print $2}')
if [ $? -eq 0 ]; then
TOTAL_MEM=$(echo "scale=1;${TOTAL_MEM}/1000" | bc)
TOTAL_MEM=$(echo "${TOTAL_MEM}" | awk '{print int($1+0.5)}')
# If RAM size is less than 4 GB, set default display manager as LightDM
if [ -e "/lib/systemd/system/lightdm.service" ] &&
[ "${TOTAL_MEM}" -lt 4 ]; then
DEFAULT_DM=$(cat "/etc/X11/default-display-manager")
if [ "${DEFAULT_DM}" != "/usr/sbin/lightdm" ]; then
echo "/usr/sbin/lightdm" > "/etc/X11/default-display-manager"
wait_debconf_resource
DEBIAN_FRONTEND=noninteractive DEBCONF_NONINTERACTIVE_SEEN=true dpkg-reconfigure lightdm
echo set shared/default-x-display-manager lightdm | debconf-communicate
fi
fi
else
echo "ERROR: Cannot get total memory size."
fi
Thank you for your reply. This operation seems to be useful, but why did my display manager change? Is it related to the operation of updating the system? Because I haven’t modified the display manager recently
That is what I want to know too.
Did you run any command like apt get upgrade recently?
Yes, because I want to try to update my jetpack package through Ota
Which version were you using and what are you using now?
Just to clarify something, if the display manager changed, then it is still running Ubuntu. That never changed. Your upgrade might have changed display manager, but unless the particular Ubuntu release changed the display manager, then it should keep the one you have. However, sometimes the same display manager will look different with a newer release. Don’t know for your case, but you’ve been running the Ubuntu distribution of Linux, and still are. I have no idea if the default display manager changed across releases.
