When I run the python script “IsaacLab/source/standalone/workflows/skrl/train.py”, it does not generate the corresponding GUI
Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
GPU Information
GPU: 4090
Driver Version : 550.120
Description
When I run the python script “IsaacLab/source/standalone/workflows/skrl/train.py”, it does not generate the corresponding GUI. The printout shows that there is something wrong with the rendering, how can I fix this problem? The printed information from the terminal is as follows.
(env_isaacsim) (base) sia@sia-Super-Server:~/IsaacLab$ /home/sia/anaconda3/envs/env_isaacsim/bin/python /home/sia/IsaacLab/source/standalone/workflows/skrl/train.py --task Isaac-Reach-Franka-v0 --num_envs 1 --enable_cameras
[INFO][AppLauncher]: Loading experience file: /home/sia/IsaacLab/source/apps/isaaclab.python.rendering.kit
[Warning] [omni.isaac.kit.simulation_app] Modules: ['omni.kit_app'] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(...)
Loading user config located at: '/home/sia/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/omni/data/Kit/Isaac-Sim/4.2/user.config.json'
[Info] [carb] Logging to file: /home/sia/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/omni/logs/Kit/Isaac-Sim/4.2/kit_20250110_111338.log
2025-01-10 03:13:38 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
| Driver Version: 550.120       | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 4090          | Yes: 0 |     | 24810   MB | 10de      | 0          |
|     |                                  |        |     |            | 2684      | a2443f5e.. |
|     |                                  |        |     |            | 51        |            |
| 1   | NVIDIA GeForce RTX 4090          |        |     | 24810   MB | 10de      | 0          |
|     |                                  |        |     |            | 2684      | 4c5e0aa7.. |
|     |                                  |        |     |            | c3        |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-51-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: Intel(R) Xeon(R) W-3335 CPU @ 3.40GHz | Cores: 16 | Logical: 32
| Total Memory (MB): 128420 | Free Memory: 111698
| Total Page/Swap (MB): 999999 | Free Page/Swap: 999999
2025-01-10 03:13:39 [1,062ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled.
2025-01-10 03:13:56 [18,202ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
CartPole-v0
CartPole-v0
CartPole-v1
CartPole-v1
MountainCar-v0
MountainCar-v0
MountainCarContinuous-v0
Pendulum-v1
Pendulum-v1
Acrobot-v1
Acrobot-v1
phys2d/CartPole-v0
phys2d/CartPole-v0
phys2d/CartPole-v1
phys2d/CartPole-v1
phys2d/Pendulum-v0
phys2d/Pendulum-v0
LunarLander-v3
LunarLander-v3
LunarLanderContinuous-v3
BipedalWalker-v3
BipedalWalker-v3
BipedalWalkerHardcore-v3
CarRacing-v3
CarRacing-v3
Blackjack-v1
Blackjack-v1
FrozenLake-v1
FrozenLake-v1
FrozenLake8x8-v1
FrozenLake8x8-v1
CliffWalking-v0
CliffWalking-v0
Taxi-v3
Taxi-v3
tabular/Blackjack-v0
tabular/CliffWalking-v0
Reacher-v2
Reacher-v2
Reacher-v4
Reacher-v4
Reacher-v5
Reacher-v5
Pusher-v2
Pusher-v2
Pusher-v4
Pusher-v4
Pusher-v5
Pusher-v5
InvertedPendulum-v2
InvertedPendulum-v2
InvertedPendulum-v4
InvertedPendulum-v4
InvertedPendulum-v5
InvertedPendulum-v5
InvertedDoublePendulum-v2
InvertedDoublePendulum-v4
InvertedDoublePendulum-v5
HalfCheetah-v2
HalfCheetah-v2
HalfCheetah-v3
HalfCheetah-v3
HalfCheetah-v4
HalfCheetah-v4
HalfCheetah-v5
HalfCheetah-v5
Hopper-v2
Hopper-v2
Hopper-v3
Hopper-v3
Hopper-v4
Hopper-v4
Hopper-v5
Hopper-v5
Swimmer-v2
Swimmer-v2
Swimmer-v3
Swimmer-v3
Swimmer-v4
Swimmer-v4
Swimmer-v5
Swimmer-v5
Walker2d-v2
Walker2d-v2
Walker2d-v3
Walker2d-v3
Walker2d-v4
Walker2d-v4
Walker2d-v5
Walker2d-v5
Ant-v2
Ant-v2
Ant-v3
Ant-v3
Ant-v4
Ant-v4
Ant-v5
Ant-v5
Humanoid-v2
Humanoid-v2
Humanoid-v3
Humanoid-v3
Humanoid-v4
Humanoid-v4
Humanoid-v5
Humanoid-v5
HumanoidStandup-v2
HumanoidStandup-v2
HumanoidStandup-v4
HumanoidStandup-v4
HumanoidStandup-v5
HumanoidStandup-v5
GymV21Environment-v0
GymV26Environment-v0
Isaac-Repose-Cube-Allegro-Direct-v0
Isaac-Ant-Direct-v0
Isaac-Ant-Direct-v0
Isaac-Velocity-Flat-Anymal-C-Direct-v0
Isaac-Velocity-Rough-Anymal-C-Direct-v0
Isaac-Cart-Double-Pendulum-Direct-v0
Isaac-Cartpole-Direct-v0
Isaac-Cartpole-RGB-Camera-Direct-v0
Isaac-Cartpole-Depth-Camera-Direct-v0
Isaac-Factory-PegInsert-Direct-v0
Isaac-Factory-GearMesh-Direct-v0
Isaac-Factory-NutThread-Direct-v0
Isaac-Franka-Cabinet-Direct-v0
Isaac-Humanoid-Direct-v0
Isaac-Quadcopter-Direct-v0
Isaac-Repose-Cube-Shadow-Direct-v0
Isaac-Repose-Cube-Shadow-OpenAI-FF-Direct-v0
Isaac-Repose-Cube-Shadow-OpenAI-LSTM-Direct-v0
Isaac-Repose-Cube-Shadow-Vision-Direct-v0
Isaac-Repose-Cube-Shadow-Vision-Direct-Play-v0
Isaac-Shadow-Hand-Over-Direct-v0
Isaac-Ant-v0
Isaac-Ant-v0
Isaac-Cartpole-v0
Isaac-Cartpole-v0
Isaac-Cartpole-RGB-v0
Isaac-Cartpole-Depth-v0
Isaac-Cartpole-RGB-ResNet18-v0
Isaac-Cartpole-RGB-TheiaTiny-v0
Isaac-Humanoid-v0
Isaac-Humanoid-v0
Isaac-Velocity-Flat-Unitree-A1-v0
Isaac-Velocity-Flat-Unitree-A1-Play-v0
Isaac-Velocity-Rough-Unitree-A1-v0
Isaac-Velocity-Rough-Unitree-A1-Play-v0
Isaac-Velocity-Flat-Anymal-B-v0
Isaac-Velocity-Flat-Anymal-B-Play-v0
Isaac-Velocity-Rough-Anymal-B-v0
Isaac-Velocity-Rough-Anymal-B-Play-v0
Isaac-Velocity-Flat-Anymal-C-v0
Isaac-Velocity-Flat-Anymal-C-Play-v0
Isaac-Velocity-Rough-Anymal-C-v0
Isaac-Velocity-Rough-Anymal-C-Play-v0
Isaac-Velocity-Flat-Anymal-D-v0
Isaac-Velocity-Flat-Anymal-D-Play-v0
Isaac-Velocity-Rough-Anymal-D-v0
Isaac-Velocity-Rough-Anymal-D-Play-v0
Isaac-Velocity-Flat-Cassie-v0
Isaac-Velocity-Flat-Cassie-Play-v0
Isaac-Velocity-Rough-Cassie-v0
Isaac-Velocity-Rough-Cassie-Play-v0
Isaac-Velocity-Rough-G1-v0
Isaac-Velocity-Rough-G1-Play-v0
Isaac-Velocity-Flat-G1-v0
Isaac-Velocity-Flat-G1-Play-v0
Isaac-Velocity-Flat-Unitree-Go1-v0
Isaac-Velocity-Flat-Unitree-Go1-Play-v0
Isaac-Velocity-Rough-Unitree-Go1-v0
Isaac-Velocity-Rough-Unitree-Go1-Play-v0
Isaac-Velocity-Flat-Unitree-Go2-v0
Isaac-Velocity-Flat-Unitree-Go2-Play-v0
Isaac-Velocity-Rough-Unitree-Go2-v0
Isaac-Velocity-Rough-Unitree-Go2-Play-v0
Isaac-Velocity-Rough-H1-v0
Isaac-Velocity-Rough-H1-Play-v0
Isaac-Velocity-Flat-H1-v0
Isaac-Velocity-Flat-H1-Play-v0
Isaac-Velocity-Flat-Spot-v0
Isaac-Velocity-Flat-Spot-Play-v0
Isaac-Open-Drawer-Franka-v0
Isaac-Open-Drawer-Franka-Play-v0
Isaac-Open-Drawer-Franka-IK-Abs-v0
Isaac-Open-Drawer-Franka-IK-Rel-v0
Isaac-Repose-Cube-Allegro-v0
Isaac-Repose-Cube-Allegro-Play-v0
Isaac-Repose-Cube-Allegro-NoVelObs-v0
Isaac-Repose-Cube-Allegro-NoVelObs-Play-v0
Isaac-Lift-Cube-Franka-v0
Isaac-Lift-Cube-Franka-Play-v0
Isaac-Lift-Cube-Franka-IK-Abs-v0
Isaac-Lift-Teddy-Bear-Franka-IK-Abs-v0
Isaac-Lift-Cube-Franka-IK-Rel-v0
Isaac-Reach-Franka-Play-v0
Isaac-Reach-Franka-IK-Abs-v0
Isaac-Reach-Franka-IK-Rel-v0
Isaac-Reach-Franka-OSC-v0
Isaac-Reach-Franka-OSC-Play-v0
Isaac-Reach-UR10-v0
Isaac-Reach-UR10-v0
Isaac-Reach-UR10-Play-v0
Isaac-Stack-Cube-Franka-v0
Isaac-Stack-Cube-Instance-Randomize-Franka-v0
Isaac-Stack-Cube-Franka-IK-Rel-v0
Isaac-Stack-Cube-Instance-Randomize-Franka-IK-Rel-v0
Isaac-Navigation-Flat-Anymal-C-v0
Isaac-Navigation-Flat-Anymal-C-Play-v0
[INFO]: Parsing configuration from: omni.isaac.lab_tasks.manager_based.manipulation.reach.config.franka.joint_pos_env_cfg:FrankaReachEnvCfg
[INFO]: Parsing configuration from: /home/sia/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/manager_based/manipulation/reach/config/franka/agents/skrl_ppo_cfg.yaml
[INFO] Logging experiment in directory: /home/sia/IsaacLab/logs/skrl/reach_franka
Setting seed: 42
[2025-01-10 11:14:06,289][ogn_registration][INFO] - Looking for Python nodes to register in omni.physx.fabric-106.1.9
[2025-01-10 11:14:06,289][ogn_registration][INFO] -  -> Registered nodes from module omni.physxfabric at /home/sia/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/isaacsim/extsPhysics/omni.physx.fabric
[2025-01-10 11:14:06,289][ogn_registration][INFO] - Registering nodes in /home/sia/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/isaacsim/extsPhysics/omni.physx.fabric imported as omni.physxfabric with AutoNode config {}
[2025-01-10 11:14:06,289][ogn_registration][INFO] - Registering Python Node Types from omni.physxfabric at /home/sia/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/isaacsim/extsPhysics/omni.physx.fabric in omni.physx.fabric
[2025-01-10 11:14:06,289][ogn_registration][INFO] - ========================================================================================================================
[2025-01-10 11:14:06,290][ogn_registration][INFO] - No dependency on omni.graph, therefore no nodes to register in omni.physx.fabric
[2025-01-10 11:14:06,290][ogn_registration][INFO] - ...None found, no registration to do
[2025-01-10 11:14:06,290][ogn_registration][INFO] - ...Skipping: No OmniGraph presence in the module omni.physxfabric - No nodes in this module, do not remember it
[2025-01-10 11:14:06,290][ogn_registration][INFO] - Destroying registration record for omni.physx.fabric
[2025-01-10 11:14:06,290][ogn_registration][INFO] - OGN register omni.physx.fabric-106.1.9 took 1437839.000000
[INFO]: Base environment:
        Environment device    : cuda:0
        Environment seed      : 42
        Physics step-size     : 0.016666666666666666
        Rendering step-size   : 0.03333333333333333
        Environment step-size : 0.03333333333333333
[INFO]: Time taken for scene creation : 2.482263 seconds
[INFO]: Scene manager:  <class InteractiveScene>
        Number of environments: 1
        Environment spacing   : 2.5
        Source prim name      : /World/envs/env_0
        Global prim paths     : []
        Replicate physics     : True
[INFO]: Starting the simulation. This may take a few seconds. Please wait...
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
