Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.9.3.10904
Host Machine Version
native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers.
I am not able understand intended use of the bind drop-down (true/false) available in dw graph ui tool?
I had created some sample cpp files with bind set to true, and when I compiled node as lib and recreated json with “nodedescriptor” tool the resulting json didn’t had anything related to bind.
Can someone point in which cases it is used? or even utilized by CGF framework, currently no info is available in documentation. Thank you.
