hi nvidia
on jetpack7.1
what thor pin is connect to cvm eeprom WP pin ?
hi nvidia
on jetpack7.1
What is your objective for setting the module EEPROM’s WP?
to avoid misoperation to write cvm EEPROM, because our camera attached to to same i2c bus,
our customer some time misoperation to write cvm EEPROM, cause boot failed.
Thank you for the explanation. The WP signal of the module’s EEPROM is directly grounded and not controllable, so there is no way to toggle it to enable write protect for your case. Is it possible to change the strapping on the camera’s side to select a non-conflicting I2C address?
hi nvidai
camera i2c address is diff cvm i2c address, but some time, our customer misoperation to use cvm i2c address as camera eeprom i2c address, Thanks !
Understood. Unfortunately, there is no way to protect against this on the module EEPROM.
