Hey there dear developers. I’m facing a problem around X with nvidia drivers loaded. 3600s after starting the X server some nvidia component is spamming the /var/log/Xorg.0.log file with a huge amount of similar messages at a high rate. This leads to sometimes 7GB sized Xorg.0.log files and fills the file system.
$ cat /var/log/Xorg.0.log
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[129705.406] Build Operating System: Linux 4.4.0-184-generic x86_64 Ubuntu
[129705.406] Current Operating System: Linux ids-geo 5.4.0-42-generic #46~18.04.1-Ubuntu SMP Fri Jul 10 07:21:24 UTC 2020 x86_64
[129705.406] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-42-generic root=UUID=6dfa9fb5-2338-45c1-bf6d-f140292e4f20 ro quiet splash vt.handoff=1
[129705.406] Build Date: 03 July 2020 07:00:25AM
[129705.406] xorg-server-hwe-18.04 2:1.20.8-2ubuntu2.2~18.04.1 (For technical support please see http://www.ubuntu.com/support)
[129705.406] Current version of pixman: 0.34.0
[129705.406] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[129705.406] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[129705.406] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 17 13:05:34 2020
[129705.406] (==) Using config file: "/etc/X11/xorg.conf"
[129705.407] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[129705.407] (==) No Layout section. Using the first Screen section.
[129705.407] (==) No screen section available. Using defaults.
[129705.407] (**) |-->Screen "Default Screen Section" (0)
[129705.407] (**) | |-->Monitor "<default monitor>"
[129705.407] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[129705.407] (**) | |-->Device "Device0"
[129705.407] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[129705.407] (==) Automatically adding devices
[129705.407] (==) Automatically enabling devices
[129705.407] (==) Automatically adding GPU devices
[129705.407] (==) Automatically binding GPU devices
[129705.407] (==) Max clients allowed: 256, resource mask: 0x1fffff
[129705.407] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[129705.407] Entry deleted from font path.
[129705.407] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[129705.407] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[129705.407] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[129705.407] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[129705.407] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[129705.407] (==) ModulePath set to "/usr/lib/xorg/modules"
[129705.407] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[129705.407] (II) Loader magic: 0x5556af286020
[129705.407] (II) Module ABI versions:
[129705.407] X.Org ANSI C Emulation: 0.4
[129705.407] X.Org Video Driver: 24.1
[129705.407] X.Org XInput driver : 24.1
[129705.407] X.Org Server Extension : 10.0
[129705.408] (++) using VT number 7
[129705.408] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[129705.408] (II) xfree86: Adding drm device (/dev/dri/card0)
[129705.412] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[129705.415] (--) PCI:*(1@0:0:0) 10de:13c2:3842:2974 rev 161, Mem @ 0xfa000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[129705.415] (II) LoadModule: "glx"
[129705.415] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[129705.416] (II) Module glx: vendor="X.Org Foundation"
[129705.416] compiled for 1.20.8, module version = 1.0.0
[129705.416] ABI class: X.Org Server Extension, version 10.0
[129705.416] (II) LoadModule: "nvidia"
[129705.416] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[129705.416] (II) Module nvidia: vendor="NVIDIA Corporation"
[129705.416] compiled for 1.6.99.901, module version = 1.0.0
[129705.416] Module class: X.Org Video Driver
[129705.416] (II) NVIDIA dlloader X Driver 450.51.05 Sun Jun 28 10:19:24 UTC 2020
[129705.416] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[129705.416] (II) Loading sub module "fb"
[129705.416] (II) LoadModule: "fb"
[129705.416] (II) Loading /usr/lib/xorg/modules/libfb.so
[129705.416] (II) Module fb: vendor="X.Org Foundation"
[129705.416] ABI class: X.Org ANSI C Emulation, version 0.4
[129705.416] (II) Loading sub module "wfb"
[129705.416] (II) LoadModule: "wfb"
[129705.416] (II) Loading /usr/lib/xorg/modules/libwfb.so
[129705.416] (II) Module wfb: vendor="X.Org Foundation"
[129705.416] (II) Loading sub module "ramdac"
[129705.417] (II) LoadModule: "ramdac"
[129705.417] (II) Module "ramdac" already built-in
[129705.417] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[129705.417] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[129705.417] (==) NVIDIA(0): RGB weight 888
[129705.417] (==) NVIDIA(0): Default visual is TrueColor
[129705.417] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[129705.417] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[129705.417] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[129705.417] (**) NVIDIA(0): Enabling 2D acceleration
[129705.417] (II) Loading sub module "glxserver_nvidia"
[129705.417] (II) LoadModule: "glxserver_nvidia"
[129705.417] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglxserver_nvidia.so
[129705.423] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[129705.423] compiled for 1.6.99.901, module version = 1.0.0
[129705.423] Module class: X.Org Server Extension
[129705.423] (II) NVIDIA GLX Module 450.51.05 Sun Jun 28 10:16:40 UTC 2020
[129705.423] (II) NVIDIA: The X server supports PRIME Render Offload.
[129705.470] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[129705.470] (--) NVIDIA(0): CRT-0
[129705.470] (--) NVIDIA(0): DFP-0 (boot)
[129705.470] (--) NVIDIA(0): DFP-1
[129705.470] (--) NVIDIA(0): DFP-2
[129705.470] (--) NVIDIA(0): DFP-3
[129705.470] (--) NVIDIA(0): DFP-4 (boot)
[129705.470] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 970 (GM204-A) at PCI:1:0:0 (GPU-0)
[129705.470] (--) NVIDIA(0): Memory: 4194304 kBytes
[129705.470] (--) NVIDIA(0): VideoBIOS: 84.04.84.00.71
[129705.470] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[129705.487] (--) NVIDIA(GPU-0): CRT-0: disconnected
[129705.487] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[129705.520] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[129705.520] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[129705.520] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[129705.520] (--) NVIDIA(GPU-0): DFP-1: disconnected
[129705.520] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[129705.520] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[129705.520] (--) NVIDIA(GPU-0): DFP-2: disconnected
[129705.520] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[129705.520] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[129705.520] (--) NVIDIA(GPU-0): DFP-3: disconnected
[129705.520] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[129705.520] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[129705.551] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): connected
[129705.551] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): Internal TMDS
[129705.551] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): 330.0 MHz maximum pixel clock
[129705.557] (==) NVIDIA(0):
[129705.557] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[129705.557] (==) NVIDIA(0): will be used as the requested mode.
[129705.558] (II) NVIDIA(0): Validated MetaModes:
[129705.558] (II) NVIDIA(0): "DFP-0:nvidia-auto-select,DFP-4:nvidia-auto-select"
[129705.558] (II) NVIDIA(0): Virtual screen size determined to be 3520 x 1200
[129705.563] (--) NVIDIA(0): DPI set to (99, 98); computed from "UseEdidDpi" X config
[129705.563] (--) NVIDIA(0): option
[129705.563] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[129705.563] (II) NVIDIA: access.
[129705.588] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select,DFP-4:nvidia-auto-select"
[129705.644] (==) NVIDIA(0): Disabling shared memory pixmaps
[129705.644] (==) NVIDIA(0): Backing store enabled
[129705.644] (==) NVIDIA(0): Silken mouse enabled
[129705.644] (==) NVIDIA(0): DPMS enabled
[129705.644] (II) Loading sub module "dri2"
[129705.644] (II) LoadModule: "dri2"
[129705.644] (II) Module "dri2" already built-in
[129705.644] (II) NVIDIA(0): [DRI2] Setup complete
[129705.644] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[129705.644] (II) Initializing extension Generic Event Extension
[129705.644] (II) Initializing extension SHAPE
[129705.645] (II) Initializing extension MIT-SHM
[129705.645] (II) Initializing extension XInputExtension
[129705.645] (II) Initializing extension XTEST
[129705.645] (II) Initializing extension BIG-REQUESTS
[129705.645] (II) Initializing extension SYNC
[129705.645] (II) Initializing extension XKEYBOARD
[129705.645] (II) Initializing extension XC-MISC
[129705.645] (II) Initializing extension SECURITY
[129705.645] (II) Initializing extension XFIXES
[129705.645] (II) Initializing extension RENDER
[129705.645] (II) Initializing extension RANDR
[129705.645] (II) Initializing extension COMPOSITE
[129705.646] (II) Initializing extension DAMAGE
[129705.646] (II) Initializing extension MIT-SCREEN-SAVER
[129705.646] (II) Initializing extension DOUBLE-BUFFER
[129705.646] (II) Initializing extension RECORD
[129705.646] (II) Initializing extension DPMS
[129705.646] (II) Initializing extension Present
[129705.646] (II) Initializing extension DRI3
[129705.646] (II) Initializing extension X-Resource
[129705.646] (II) Initializing extension XVideo
[129705.646] (II) Initializing extension XVideo-MotionCompensation
[129705.646] (II) Initializing extension SELinux
[129705.646] (II) SELinux: Disabled on system
[129705.646] (II) Initializing extension GLX
[129705.646] (II) Indirect GLX disabled.
[129705.646] (II) GLX: Another vendor is already registered for screen 0
[129705.646] (II) Initializing extension XFree86-VidModeExtension
[129705.646] (II) Initializing extension XFree86-DGA
[129705.646] (II) Initializing extension XFree86-DRI
[129705.646] (II) Initializing extension DRI2
[129705.646] (II) Initializing extension NV-GLX
[129705.647] (II) Initializing extension NV-CONTROL
[129705.647] (II) Initializing extension XINERAMA
[129705.689] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[129705.689] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[129705.689] (II) LoadModule: "libinput"
[129705.689] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[129705.690] (II) Module libinput: vendor="X.Org Foundation"
[129705.690] compiled for 1.20.1, module version = 0.28.1
[129705.690] Module class: X.Org XInput Driver
[129705.690] ABI class: X.Org XInput driver, version 24.1
[129705.690] (II) Using input driver 'libinput' for 'Power Button'
[129705.690] (**) Power Button: always reports core events
[129705.690] (**) Option "Device" "/dev/input/event1"
[129705.690] (**) Option "_source" "server/udev"
[129705.690] (II) event1 - Power Button: is tagged by udev as: Keyboard
[129705.690] (II) event1 - Power Button: device is a keyboard
[129705.690] (II) event1 - Power Button: device removed
[129705.714] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[129705.714] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[129705.714] (**) Option "xkb_model" "pc105"
[129705.714] (**) Option "xkb_layout" "de"
[129705.736] (II) event1 - Power Button: is tagged by udev as: Keyboard
[129705.736] (II) event1 - Power Button: device is a keyboard
[129705.737] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[129705.737] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[129705.737] (II) Using input driver 'libinput' for 'Power Button'
[129705.737] (**) Power Button: always reports core events
[129705.737] (**) Option "Device" "/dev/input/event0"
[129705.737] (**) Option "_source" "server/udev"
[129705.737] (II) event0 - Power Button: is tagged by udev as: Keyboard
[129705.737] (II) event0 - Power Button: device is a keyboard
[129705.737] (II) event0 - Power Button: device removed
[129705.766] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[129705.766] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[129705.766] (**) Option "xkb_model" "pc105"
[129705.766] (**) Option "xkb_layout" "de"
[129705.766] (II) event0 - Power Button: is tagged by udev as: Keyboard
[129705.766] (II) event0 - Power Button: device is a keyboard
[129705.767] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[129705.767] (II) No input driver specified, ignoring this device.
[129705.767] (II) This device may have been added with another device file.
[129705.768] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[129705.768] (II) No input driver specified, ignoring this device.
[129705.768] (II) This device may have been added with another device file.
[129705.768] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event16)
[129705.769] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event17)
[129705.769] (II) No input driver specified, ignoring this device.
[129705.769] (II) This device may have been added with another device file.
[129705.770] (II) config/udev: Adding input device Cherry USB keyboard (/dev/input/event2)
[129705.770] (**) Cherry USB keyboard: Applying InputClass "libinput keyboard catchall"
[129705.770] (II) Using input driver 'libinput' for 'Cherry USB keyboard'
[129705.770] (**) Cherry USB keyboard: always reports core events
[129705.770] (**) Option "Device" "/dev/input/event2"
[129705.770] (**) Option "_source" "server/udev"
[129705.771] (II) event2 - Cherry USB keyboard: is tagged by udev as: Keyboard
[129705.771] (II) event2 - Cherry USB keyboard: device is a keyboard
[129705.771] (II) event2 - Cherry USB keyboard: device removed
[129705.802] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.0/0003:046A:B090.0001/input/input2/event2"
[129705.802] (II) XINPUT: Adding extended input device "Cherry USB keyboard" (type: KEYBOARD, id 8)
[129705.802] (**) Option "xkb_model" "pc105"
[129705.802] (**) Option "xkb_layout" "de"
[129705.803] (II) event2 - Cherry USB keyboard: is tagged by udev as: Keyboard
[129705.803] (II) event2 - Cherry USB keyboard: device is a keyboard
[129705.804] (II) config/udev: Adding input device Cherry USB keyboard System Control (/dev/input/event3)
[129705.804] (**) Cherry USB keyboard System Control: Applying InputClass "libinput keyboard catchall"
[129705.804] (II) Using input driver 'libinput' for 'Cherry USB keyboard System Control'
[129705.804] (**) Cherry USB keyboard System Control: always reports core events
[129705.804] (**) Option "Device" "/dev/input/event3"
[129705.804] (**) Option "_source" "server/udev"
[129705.805] (II) event3 - Cherry USB keyboard System Control: is tagged by udev as: Keyboard
[129705.805] (II) event3 - Cherry USB keyboard System Control: device is a keyboard
[129705.805] (II) event3 - Cherry USB keyboard System Control: device removed
[129705.830] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.1/0003:046A:B090.0002/input/input3/event3"
[129705.830] (II) XINPUT: Adding extended input device "Cherry USB keyboard System Control" (type: KEYBOARD, id 9)
[129705.830] (**) Option "xkb_model" "pc105"
[129705.830] (**) Option "xkb_layout" "de"
[129705.831] (II) event3 - Cherry USB keyboard System Control: is tagged by udev as: Keyboard
[129705.831] (II) event3 - Cherry USB keyboard System Control: device is a keyboard
[129705.832] (II) config/udev: Adding input device Cherry USB keyboard Consumer Control (/dev/input/event4)
[129705.832] (**) Cherry USB keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[129705.832] (II) Using input driver 'libinput' for 'Cherry USB keyboard Consumer Control'
[129705.832] (**) Cherry USB keyboard Consumer Control: always reports core events
[129705.832] (**) Option "Device" "/dev/input/event4"
[129705.832] (**) Option "_source" "server/udev"
[129705.833] (II) event4 - Cherry USB keyboard Consumer Control: is tagged by udev as: Keyboard
[129705.833] (II) event4 - Cherry USB keyboard Consumer Control: device is a keyboard
[129705.833] (II) event4 - Cherry USB keyboard Consumer Control: device removed
[129705.862] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.1/0003:046A:B090.0002/input/input4/event4"
[129705.862] (II) XINPUT: Adding extended input device "Cherry USB keyboard Consumer Control" (type: KEYBOARD, id 10)
[129705.862] (**) Option "xkb_model" "pc105"
[129705.862] (**) Option "xkb_layout" "de"
[129705.863] (II) event4 - Cherry USB keyboard Consumer Control: is tagged by udev as: Keyboard
[129705.863] (II) event4 - Cherry USB keyboard Consumer Control: device is a keyboard
[129705.864] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event5)
[129705.864] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[129705.864] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[129705.864] (**) Logitech USB Optical Mouse: always reports core events
[129705.864] (**) Option "Device" "/dev/input/event5"
[129705.864] (**) Option "_source" "server/udev"
[129705.865] (II) event5 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[129705.865] (II) event5 - Logitech USB Optical Mouse: device is a pointer
[129705.865] (II) event5 - Logitech USB Optical Mouse: device removed
[129705.926] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-14/3-14:1.0/0003:046D:C077.0003/input/input5/event5"
[129705.926] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 11)
[129705.926] (**) Option "AccelerationScheme" "none"
[129705.926] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[129705.926] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[129705.926] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[129705.927] (II) event5 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[129705.927] (II) event5 - Logitech USB Optical Mouse: device is a pointer
[129705.928] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[129705.928] (II) No input driver specified, ignoring this device.
[129705.928] (II) This device may have been added with another device file.
[129705.929] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event10)
[129705.929] (II) No input driver specified, ignoring this device.
[129705.929] (II) This device may have been added with another device file.
[129705.929] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event11)
[129705.930] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event12)
[129705.930] (II) No input driver specified, ignoring this device.
[129705.930] (II) This device may have been added with another device file.
[129705.931] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event13)
[129705.931] (II) No input driver specified, ignoring this device.
[129705.931] (II) This device may have been added with another device file.
[129705.931] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event7)
[129705.932] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event8)
[129705.932] (II) No input driver specified, ignoring this device.
[129705.932] (II) This device may have been added with another device file.
[129705.932] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event9)
[129705.933] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event6)
[129705.933] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[129705.933] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[129705.933] (**) Eee PC WMI hotkeys: always reports core events
[129705.933] (**) Option "Device" "/dev/input/event6"
[129705.933] (**) Option "_source" "server/udev"
[129705.934] (II) event6 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[129705.934] (II) event6 - Eee PC WMI hotkeys: device is a keyboard
[129705.934] (II) event6 - Eee PC WMI hotkeys: device removed
[129705.958] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input6/event6"
[129705.958] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 12)
[129705.958] (**) Option "xkb_model" "pc105"
[129705.958] (**) Option "xkb_layout" "de"
[129705.958] (II) event6 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[129705.958] (II) event6 - Eee PC WMI hotkeys: device is a keyboard
[132744.203] (--) NVIDIA(GPU-0): CRT-0: disconnected
[132744.203] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[132744.235] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[132744.235] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[132744.235] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[132744.235] (--) NVIDIA(GPU-0): DFP-1: disconnected
[132744.235] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[132744.235] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[132744.235] (--) NVIDIA(GPU-0): DFP-2: disconnected
[132744.235] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[132744.235] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[132744.235] (--) NVIDIA(GPU-0): DFP-3: disconnected
[132744.235] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[132744.235] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[132744.266] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): connected
[132744.266] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): Internal TMDS
[132744.266] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): 330.0 MHz maximum pixel clock
[132744.283] (--) NVIDIA(GPU-0): CRT-0: disconnected
[132744.283] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[132744.316] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): connected
[132744.316] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): Internal TMDS
[132744.316] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[132744.316] (--) NVIDIA(GPU-0): DFP-1: disconnected
[132744.316] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[132744.316] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[132744.316] (--) NVIDIA(GPU-0): DFP-2: disconnected
[132744.316] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[132744.316] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[132744.316] (--) NVIDIA(GPU-0): DFP-3: disconnected
[132744.316] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[132744.316] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[132744.347] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): connected
[132744.347] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): Internal TMDS
[132744.347] (--) NVIDIA(GPU-0): Samsung S24C650 (DFP-4): 330.0 MHz maximum pixel clock
[132744.368] (--) NVIDIA(GPU-0): CRT-0: disconnected
[132744.368] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
The last lines
are repeated a million times. Here some additional infos about the system and nvidia driver
$ modinfo nvidia
filename: /lib/modules/5.4.0-42-generic/updates/dkms/nvidia.ko
alias: char-major-195-*
version: 450.51.05
supported: external
license: NVIDIA
srcversion: EAC48A690FFFFCEEFF53536
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
retpoline: Y
vermagic: 5.4.0-42-generic SMP mod_unload
signat: PKCS#7
signer:
sig_key:
sig_hashalgo: md4
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: nv_cap_enable_devfs:nv_cap_enable_devfs=0 or 1 (int)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_MapRegistersEarly:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_EnableBacklightHandler:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_AssignGpus:charp
$ uname -r
5.4.0-42-generic
$ lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu 18.04.5 LTS
Release: 18.04
Codename: bionic
Please tell me what else you may need to identify the source of the problem.
