Xavier can support 8K video Encoder?
8K encoding is not listed in Xavier module data sheet, but the function should work on next Jetpack 4.6. Once it is released, you may give it a try. If you can put frame data in NvBuffer/NVMM buffer directly, it can achieve optimal performance.
