[0000.375] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-aa987a31)
[0000.375] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.376] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.376] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.382] W> device prod register failed
[0000.386] I> Boot-device: QSPI
[0000.389] I> Boot_device: QSPI_FLASH instance: 0
[0000.394] I> QSPI Flash Size = 32 MB
[0000.397] I> Qspi initialized successfully
[0000.401] I> qspi flash-0 params source = boot args
[0000.798] I> sdmmc DDR50 mode
[0000.800] I> sdmmc-3 params source = safe params
[0000.804] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.806] W> Cannot find any partition table for 00000003
[0000.808] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.809] W> No valid slot number is found in scratch register
[0000.809] W> Return default slot: _a
[0000.810] I> Active Boot chain : 0
[0000.811] I> parsing oem signed section of bpmp-fw header done
[0000.814] I> bpmp-fw binary init read from storage
[0000.819] I> oem authentication of bpmp-fw header done
[0000.833] I> bpmp-fw binary done read from storage
[0000.834] I> bpmp-fw: Authentication init Done
[0000.835] I> parsing oem signed section of cpubl header done
[0000.838] I> cpubl binary init read from storage
[0000.843] I> bpmp-fw: Authentication Finalize Done
[0000.848] I> oem authentication of cpubl header done
[0000.855] I> cpubl binary done read from storage
[0000.857] I> cpubl: Authentication init Done
[0000.861] I> parsing oem signed section of rce header done
[0000.866] I> rce binary init read from storage
[0000.871] I> Relocating BR-BCT
[0000.873] I> cpubl: Authentication Finalize Done
[0000.878] I> oem authentication of rce header done
[0000.883] I> rce binary done read from storage
[0000.887] I> rce: Authentication init Done
[0000.891] I> parsing oem signed section of ape header done
[0000.896] I> ape binary init read from storage
[0000.900] I> rce: Authentication Finalize Done
[0000.905] I> oem authentication of ape header done
[0000.909] I> ape binary done read from storage
[0000.913] I> ape: Authentication init Done
[0000.918] I> parsing oem signed section of tos header done
[0000.923] I> tos binary init read from storage
[0000.927] I> ape: Authentication Finalize Done
[0000.932] I> oem authentication of tos header done
[0000.938] I> tos binary done read from storage
[0000.940] I> tos: Authentication init Done
[0000.945] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.950] I> bpmp-fw-dtb binary init read from storage
[0000.955] I> tos: Authentication Finalize Done
[0000.961] I> oem authentication of bpmp-fw-dtb header done
[0000.965] I> bpmp-fw-dtb binary done read from storage
[0000.970] I> bpmp-fw-dtb: Authentication init Done
[0000.975] I> parsing oem signed section of cpubl-dtb header done
[0000.980] I> cpubl-dtb binary init read from storage
[0000.985] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.032] I> oem authentication of cpubl-dtb header done
[0001.032] I> cpubl-dtb binary done read from storage
[0001.033] I> cpubl-dtb: Authentication init Done
[0001.034] I> parsing oem signed section of eks header done
[0001.035] I> eks binary init read from storage
[0001.035] I> cpubl-dtb: Authentication Finalize Done
[0001.036] I> oem authentication of eks header done
[0001.040] I> eks binary done read from storage
[0001.045] I> eks: Authentication init Done
[0001.049] I> eks: Authentication Finalize Done
[0001.053] I> EKB detected (length: 0x410) @ VA:0x52714400
▒▒NOTICE: BL31: v1.3(release):fe06da916
NOTICE: BL31: Built : 18:06:49, Apr 8 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.394] I> Welcome to Cboot
▒▒WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
▒▒[0001.395] I> Cboot Version: t194-d00c695c
[0001.397] I> CPU-BL Params @ 0xf2820000
[0001.400] I> 0) Base:0x00000000 Size:0x00000000
[0001.405] I> 1) Base:0xf1100000 Size:0x00100000
[0001.409] I> 2) Base:0xf2000000 Size:0x00200000
[0001.414] I> 3) Base:0xf1200000 Size:0x00200000
▒▒clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.418] I> 4) Base:0xf1000000 Size:0x00100000
[0001.562] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.567] I> 6) Base:0xf3800000 Size:0x00400000
[0001.571] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.575] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.580] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.584] I> 10) Base:0xf3000000 Size:0x00800000
[0001.589] I> 11) Base:0x40000000 Size:0x00040000
[0001.593] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.598] I> 13) Base:0x40046000 Size:0x00002000
[0001.602] I> 14) Base:0x40048000 Size:0x00002000
[0001.607] I> 15) Base:0xac000000 Size:0x00004000
[0001.611] I> 16) Base:0x4004a000 Size:0x00002000
[0001.616] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.620] I> 18) Base:0x4004c000 Size:0x00002000
[0001.625] I> 19) Base:0xf2200000 Size:0x00600000
[0001.629] I> 20) Base:0x4004e000 Size:0x00002000
[0001.633] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.638] I> 22) Base:0x00000000 Size:0x00000000
[0001.642] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.647] I> 24) Base:0xf6000000 Size:0x02000000
[0001.651] I> 25) Base:0x40050000 Size:0x00002000
[0001.656] I> 26) Base:0x40040000 Size:0x00006000
[0001.660] I> 27) Base:0xf1800000 Size:0x00400000
[0001.665] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.669] I> 29) Base:0xf1400000 Size:0x00400000
[0001.674] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.678] I> 31) Base:0x00000000 Size:0x00000000
[0001.683] I> 32) Base:0xf8000000 Size:0x08000000
[0001.687] I> 33) Base:0x00000000 Size:0x00000000
[0001.691] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.696] I> 35) Base:0xab000000 Size:0x01000000
[0001.700] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.705] I> 37) Base:0xf2800000 Size:0x00800000
[0001.709] I> 38) Base:0x80000000 Size:0x20000000
[0001.714] I> 39) Base:0xb0000000 Size:0x08000000
[0001.718] I> 40) Base:0x00000000 Size:0x00000000
[0001.723] I> 41) Base:0x00000000 Size:0x00000000
[0001.727] I> 42) Base:0x00000000 Size:0x00000000
[0001.732] I> 43) Base:0x00000000 Size:0x00000000
[0001.736] I> 44) Base:0x00000000 Size:0x00000000
[0001.741] I> 45) Base:0x00000000 Size:0x00000000
[0001.745] GIC-SPI Target CPU: 0
[0001.748] Interrupts Init done
[0001.751] calling constructors
[0001.754] initializing heap
[0001.756] I> Heap: [0xa06905a8 ... 0xab000000]
[0001.761] initializing threads
[0001.764] initializing timers
[0001.766] creating bootstrap completion thread
[0001.771] top of bootstrap2()
[0001.773] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.778] initializing platform
[0001.781] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.787] W> device prod register failed
[0001.790] I> Bl_dtb @0xaaf00000
[0001.796] E> "plugin-manager" doesn't exist, creating
[0001.798] E> "ids" doesn't exist, creating
[0001.802] E> "connection" doesn't exist, creating
[0001.807] E> "configs" doesn't exist, creating
[0001.815] I> Find /i2c@3160000's alias i2c0
[0001.815] I> Reading eeprom i2c=0 address=0x50
[0001.821] E> I2C: slave not found in slaves.
[0001.823] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.831] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.837] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.846] E> eeprom: Failed to read I2C slave device
[0001.851] I> Eeprom read failed 0x3526070d
[0001.855] I> Reading eeprom i2c=0 address=0x57
[0001.859] E> I2C: slave not found in slaves.
[0001.863] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.871] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.877] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.886] E> eeprom: Failed to read I2C slave device
[0001.891] I> Eeprom read failed 0x3526070d
[0001.897] I> Find /i2c@c240000's alias i2c1
[0001.899] I> Reading eeprom i2c=1 address=0x50
[0001.905] E> I2C: slave not found in slaves.
[0001.908] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.915] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.921] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.930] E> eeprom: Retry to read I2C slave device.
[0001.935] E> I2C: slave not found in slaves.
[0001.939] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.947] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.953] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.962] E> eeprom: Failed to read I2C slave device
[0001.967] I> Eeprom read failed 0x3526070d
[0001.973] E> "chip-id" doesn't exist, creating
[0001.975] I> Adding plugin-manager/chip-id/A02P
[0001.980] I> Plugin-manager override starting
[0001.985] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.995] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.004] I> Disable plugin-manager status in FDT
[0002.004] I> Plugin-manager override finished successfully
[0002.005] I> gpio framework initialized
[0002.010] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.018] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.024] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.031] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.039] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.046] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.052] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.059] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.067] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.074] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.081] I> fixed regulator driver initialized
[0002.088] I> register 'maxim' power off handle
[0002.089] I> virtual i2c enabled
[0002.091] I> registered 'maxim,max20024' pmic
[0002.096] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.102] I> Boot-device: QSPI
[0002.105] I> Boot_device: QSPI_FLASH instance: 0
[0002.110] I> QSPI source rate = 204000 Khz
[0002.114] I> Requested rate for QSPI clock = 34000 Khz
[0002.119] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.124] I> QSPI Flash Size = 32 MB
[0002.127] I> Qspi initialized successfully
[0002.131] I> qspi flash-0 params source = boot args
[0002.140] I> sdmmc-3 params source = safe params
[0002.141] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.161] W> Cannot find any partition table for 00000003
[0002.174] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.182] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.186] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.187] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.187] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.191] E> invalid display type
[0002.192] E> cannot find any other nvdisp nodes
[0002.192] E> no valid display unit config found in dtb
[0002.194] W> display init failed
[0002.195] I> Load in CBoot Boot Options partition and parse it
[0002.202] E> Error -9 when finding node with path /boot-configuration
[0002.207] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.215] I> Hit any key to stop autoboot: 4 3 2 1
[0004.222] initializing target
[0004.222] calling apps_init()
[0004.223] starting app kernel_boot_app
[0004.229] I> found decompressor handler: lz4-legacy
[0004.229] I> decompressing BMP blob ...
[0004.233] I> Kernel type = Normal
[0004.233] I> Loading kernel-bootctrl from partition
[0004.234] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x1)
[0004.242] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.242] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.243] I> ########## SD boot ##########
[0004.247] I> No sdcard
[0004.249] I> -0 params source =
[0004.252] E> Blockdev open: exit error
[0004.256] E> SD boot failed, err: 724238353
[0004.260] I> ########## USB boot ##########
[0004.269] W> No valid slot number is found in scratch register
[0004.270] W> Return default slot: _a
[0004.281] I> USB Firmware Version: 60.06 release
[0004.336] I> regulator of usb2-0 already enabled
[0004.341] I> regulator of usb2-1 already enabled
[0004.348] I> enabling 'vdd-usb2-5v' regulator
[0005.348] E> failed to initialize xhci controller
[0005.348] E> Error in init of XUSB host driver, err: 79790026
[0005.349] E> Failed to initialize device 5-0
[0005.349] E> USB boot failed, err: 2037973030
[0005.349] I> ########## Fixed storage boot ##########
[0005.350] I> Already published: 00010003
[0005.350] I> Look for boot partition
[0005.353] I> Fallback: assuming 0th partition is boot partition
[0005.359] I> Detect filesystem
[0005.386] I> Loading extlinux.conf ...
[0005.387] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.423] I> L4T boot options
[0005.424] I> [1]: "primary kernel"
[0005.424] I> Enter choice:
[0008.425] I> Continuing with default option: 1
[0008.425] I> Loading kernel sig file from rootfs ...
[0008.425] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.444] I> Loading kernel binary from rootfs ...
[0008.444] I> rootfs path: /sdmmc_user/boot/Image
[0008.864] I> Validate kernel ...
[0008.864] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.201] I> No kernel-dtb binary path
[0009.201] W> No valid slot number is found in scratch register
[0009.202] W> Return default slot: _a
[0009.202] I> A/B: bin_type (38) slot 0
[0009.202] I> Loading kernel-dtb from partition
[0009.203] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.214] I> Validate kernel-dtb ...
[0009.214] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.218] I> Loading ramdisk from rootfs ...
[0009.218] I> rootfs path: /sdmmc_user/boot/initrd
[0009.299] I> Kernel hdr @0xa42b0000
[0009.299] I> Kernel dtb @0x90000000
[0009.299] I> decompressor handler not found
[0009.300] I> Copying kernel image (34265104 bytes) from 0xa42b0000 to 0x80080000 ... [0009.311] I> Done
[0009.312] I> Updated bpmp info to DTB
[0009.313] I> Ramdisk: Base: 0x92000000; Size: 0x54ec8f
[0009.314] I> Updated initrd info to DTB
[0009.314] W> WARN: Fail to override "console=none" in commandline
[0009.314] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.319] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.326] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.334] W> No valid slot number is found in scratch register
[0009.339] W> Return default slot: _a
[0009.343] I> Active slot suffix:
[0009.346] I> add_boot_slot_suffix: slot_suffix =
[0009.351] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_ comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.383] I> Updated bootarg info to DTB
[0009.387] E> Error 892665857: Failed to get CVM EEPROM contents
[0009.392] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0009.399] E> Failed to get WIFI MAC address
[0009.403] E> Error 892665857: Failed to get CVM EEPROM contents
[0009.408] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0009.415] E> Failed to get Bluetooth MAC address
[0009.419] E> Error 892665857: Failed to get CVM EEPROM contents
[0009.425] E> Booting w/o MAC ddresses for WIFI, Bluetooth & Ethernet
[0009.431] E> Failed to get Ethernet MAC address
[0009.436] E> "plugin-manager" doesn't exist, creating
[0009.440] E> "chip-id" doesn't exist, creating
[0009.445] I> Adding /chosen/plugin-manager/chip-id
[0009.449] E> "configs" doesn't exist, creating
[0009.454] I> Adding /chosen/plugin-manager/configs
[0009.458] E> "ids" doesn't exist, creating
[0009.462] I> Adding /chosen/plugin-manager/ids
[0009.466] E> "odm-data" doesn't exist, creating
[0009.471] I> Adding /chosen/plugin-manager/odm-data
[0009.478] E> "memory" doesn't exist, creating
[0009.480] I> [0] START: 0x80000000, END: 0xac000000
[0009.484] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.489] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.494] I> dram_block larger than 80000000
[0009.498] I> [3] START: 0x100000000, END: 0x280000000
[0009.503] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.509] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.515] I> added [base:0x100000000, size:0x180000000] to /memory
[0009.522] I> Updated memory info to DTB
[0009.525] E> add_disp_param: failed to get display params for du=0
[0009.531] E> "reset" doesn't exist, creating
[0009.535] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.539] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.544] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.549] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.553] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.558] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.563] I> Deleted cpu@6 node in DT
[0009.566] I> Deleted cpu@7 node in DT
[0009.570] I> Deleted cluster3 node in FDT
[0009.574] I> Update arm-pmu in FDT
[0009.577] I> - update property: interrupts
[0009.581] I> - update property: interrupt-affinity
[0009.586] E> "misc-data" doesn't exist, creating
[0009.590] I> Boot-device: QSPI
[0009.593] W> Unknown boot device
[0009.596] I> Add storage-qspi to plugin-manager/misc-data
[0009.601] W> Unknown storage device
[0009.605] E> Error 892665857: Failed to read CVM EEPROM
[0009.610] E> Failed to get serial number
[0009.613] I> Plugin-manager override starting
[0009.618] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.625] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.633] I> Disable plugin-manager status in FDT
[0009.634] I> Plugin-manager override finished successfully
[0009.639] I> tegrabl_load_kernel_and_dtb: Done
[0009.643] E> tegrabl_display_clear: display is not initialized
[0009.649] W> Boot logo display failed...
[0009.653] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3193) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018 .05) ) #1 SMP PREEMPT Wed Apr 8 18:15:20 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
▒▒WARNING: at platform/drivers/pg/pg-cv-t194.c:73
▒▒[ 1.684812] eqos_get_mac_address_dtb: bad mac address at /chosen/nvidia,ether-mac: null.
[ 1.685039] eqos 2490000.ether_qos (unnamed net_device) (uninitialized): ether-mac read from DT failed -99
[ 1.861463] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.861681] imx219 9-0010: board setup failed
[ 1.885698] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.885938] imx219 10-0010: board setup failed
▒▒WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
▒▒[ 3.620732] cgroup: cgroup2: unknown option "nsdelegate"
▒▒[ 5.202609] using random self ethernet address
[ 5.202738] using random host ethernet address
[ 5.291083] random: crng init done
[ 5.291199] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.839769] using random self ethernet address
[ 5.839893] using random host ethernet address
[ 6.170058] CPU2: shutdown
[ 6.246375] CPU3: shutdown
[ 6.306260] CPU4: shutdown
[ 6.346046] CPU5: shutdown
Ubuntu 18.04.4 LTS tegra-nx ttyTCU0
tegra-nx login:
