Xavier NX Peak Current
In the datasheet for the NX it calls out a peak current of 5A, however in other posts users have found that NX peak currents can go as high as 9.5A for non-trivial time periods. I’m trying to design an appropriate power supply for the 5V rail. Can you provide what Current the supply should be rated for?
Thanks,
Peter
IDDmax is 5A for module. Custom design should refer to that for power supply to module. As for the peak current, it should consider the power of carrier board too.
