There is something unclear in SYS_RESET_N (L60) pin direction,
In the Jetson_Xavier_OEM_Product_Design_Guide and JetsonXavierSOMDataSheet_v0.9 documents this pin is discribed as output pin, But it is look like this pin should be bidirectional type since it is writen on the pin description:
“…Can also be driven from carrier board to module…”
to initiate full system reset" so if it “Can be driven from”, it is also an input pin.
Please explain. is the reis a mistake on the data sheet and the Design Guid documents or there is something that I`m missing?
Regards,
Yaniv.
It should be Bidir and will be corrected in next release, thanks.
