Xavier appears for 40 minutes, the temperature rises to more than 60 degrees, and the normal core is about 55 degrees a day. What is the problem with this core
Just 40 minutes
hello junxing.liang,
is your fan device actually spinning?
Every time, no other normal ones
the fan mode is set to “quiet” by default, could you please modify the default fan mode as “cool”.
please review /etc/nvpmodel.conf , you should check FAN_CONFIG DEFAULT in the configuration file.
besides, please also refer to Thermal Specifications for reference,
thanks
This is a module, not a development kit
it depends-on your use-case, you may also have your own thermal solution, please check below documentations,
for example, Jetson AGX Xavier Series OEM Product Design Guide, and Jetson AGX Xavier Series Thermal Design Guide.
thanks
