jetson orin dev kit with Jetpack 6.1 is not detecting ’ joystick’ attached to USB port. solution please.
It seems you have reported similar issue before, see Jetpack 6.0 microsoft xbox joystick not working with kernel 5.15 - Jetson & Embedded Systems / Jetson Orin Nano - NVIDIA Developer Forums
So JP6.0 can work, but not on JP6.1?
And please check the posts:
Jetson/L4T/r36.3.x patches - eLinux.org
Enable Joystick/F710 controller
Thank you so much, xpad is working perfectly.
