I am just starting learning to use Create, and if I add a plane to a scene, then change the X scale, the plane gets bigger. If I adjust the Y scale, nothing happens.
Can someone confirm this is a bug? Is there another way to make the plane bigger?
If you look at the small coordinate system icon in the bottom left, that shows the green y-axis going up.
Your plane is defined in the red x- and blue z-axis plane only, so it has zero y-height and y-scaling won’t change that.
Try adjusting the x- and z-scaling instead.
