TL;dr: The Seed Studios A206 carrier board requires a modification to reliably run TX2 NX modules. See linked post below for the mod.
I recently picked up a Seeed Studios A206 carrier board and a TX2 NX module. I ran into frustrating issues with flashing and booting:
- Board appeared dead when power applied - no power LED
- Despite no LED, module did appear in
lsusb
output and was detected bysdkmanager
sdkmanager
GUI failed to flash with an error similar
INFO: Flash Jetson TX2 - flash: UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xa4 in position 16: invalid start byte
- I was able to flash using the
flash.sh
script - While flashing, the A206 power LED came on
- After flashing, the TX2 NX module did appear to boot, but HDMI didn’t appear
- After some time a USB-serial interface appeared on the host machine from the micro-USB port
- On 40-pin header, 5v was present but 3v3 was dead
- VUSB was not present on any of the USB-A ports
- Switching to a different monitor, I found the HDMI port was active with the setup screen, but I could not use USB keyboard
While desperately trying to find a schematic for the A206 board (which I would still love to find), I stumbled across this thread.
I was skeptical, but I had no other leads. After a half-hearted effort at removing the resistor with a soldering iron I decided to go for broke and snip the resistor. If it is in fact just a pull-down resistor and if I need to replace it, the exact value is not critical so I don’t need to recover the component to reuse or at least measure.
RESULT: PASS
Removing the resistor mentioned in the linked post fixed all of my problems. The board now flashes fine with sdkmanager
, the HDMI and USB ports work, the 3.3v rail is alive, and the power LED comes on even if the board is in recovery mode.
This appears to be a mandatory modification to reliably run a TX2 NX module with the A206 carrier board. I’m not sure how it affects other modules.
