A30: IsaacSim crashed when launch
Hello everyone.
  1. I am using A30.
  2. I strictly followed the instruction here: Isaac Sim | NVIDIA NGC
  3. output from command: ./x86_64/bin/vulkaninfo (link: Linux Troubleshooting — Omniverse Developer Guide latest documentation (nvidia.com))
    GPU0:
    VkPhysicalDeviceProperties:
    apiVersion        = 1.1.182 (4198582)
    driverVersion     = 0.0.1 (1)
    vendorID          = 0x10005
    deviceID          = 0x0000
    deviceType        = PHYSICAL_DEVICE_TYPE_CPU
    deviceName        = llvmpipe (LLVM 12.0.0, 256 bits)
    pipelineCacheUUID = 76616c2d-696d-6500-0000-000000000000
  1. the crash log:
  2. 2024-08-05 06:21:19 [595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
    2024-08-05 06:21:19 [595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘22.04.3 LTS (Jammy Jellyfish)’
    2024-08-05 06:21:19 [595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘22.04.3’
    2024-08-05 06:21:19 [595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
    2024-08-05 06:21:19 [595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
    2024-08-05 06:21:19 [595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runningInContainer = ‘1’
    2024-08-05 06:21:19 [596ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ‘’
    2024-08-05 06:21:19 [596ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘20830725366713125’
    2024-08-05 06:21:19 [596ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
    2024-08-05 06:21:19 [596ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
    2024-08-05 06:21:19 [596ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/isaac-sim’
    2024-08-05 06:21:19 [596ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 24 backtrace follows:
    2024-08-05 06:21:19 [604ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50
    2024-08-05 06:21:19 [608ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libimgui.so!ImGui::PushStyleColor(int, ImVec4 const&)+0x2a
    2024-08-05 06:21:19 [610ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libcarb.imgui.plugin.so!_init+0x366f
    2024-08-05 06:21:19 [613ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: imgui.cpython-310-x86_64-linux-gnu.so!std::vector<std::string, std::allocatorstd::string >::~vector()+0x12154
    2024-08-05 06:21:19 [616ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: imgui.cpython-310-x86_64-linux-gnu.so!std::vector<std::string, std::allocatorstd::string >::~vector()+0x159e5
    2024-08-05 06:21:19 [620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libpython3.10.so.1.0!PyBuffer_ToContiguous+0x9a7
    2024-08-05 06:21:19 [624ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libpython3.10.so.1.0!_PyObject_MakeTpCall+0x9a
    2024-08-05 06:21:19 [628ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libpython3.10.so.1.0!PyCell_Set+0x8b5
    2024-08-05 06:21:19 [632ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libpython3.10.so.1.0!_init+0xbaed
    2024-08-05 06:21:19 [636ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x6e78
    2024-08-05 06:21:19 [639ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
    2024-08-05 06:21:19 [643ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libpython3.10.so.1.0!_init+0xbaed
    2024-08-05 06:21:19 [647ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x38bc
    2024-08-05 06:21:19 [650ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
    2024-08-05 06:21:19 [654ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libpython3.10.so.1.0!PyVectorcall_Call+0x54
    2024-08-05 06:21:19 [658ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x5745
    2024-08-05 06:21:19 [661ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
    2024-08-05 06:21:19 [665ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libpython3.10.so.1.0!_init+0xbaed
    2024-08-05 06:21:19 [669ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x38bc
    2024-08-05 06:21:19 [672ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
    2024-08-05 06:21:19 [676ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libpython3.10.so.1.0!_init+0xbaed
    2024-08-05 06:21:19 [680ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x38bc
    2024-08-05 06:21:19 [683ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
    2024-08-05 06:21:19 [687ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libpython3.10.so.1.0!_init+0xbaed
    2024-08-05 06:21:19 [691ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x6e78
    2024-08-05 06:21:19 [694ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libpython3.10.so.1.0!PyEval_EvalCode+0x504
    2024-08-05 06:21:19 [698ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libcarb.scripting-python.plugin.so!carbOnPluginShutdown+0x98c
    2024-08-05 06:21:19 [701ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libcarb.scripting-python.plugin.so!carbOnPluginShutdown+0x117f
    2024-08-05 06:21:19 [705ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libomni.ext.plugin.so!std::string& std::vector<std::string, std::allocatorstd::string >::emplace_back<char const*&>(char const*&)+0xd158
    2024-08-05 06:21:19 [709ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libomni.ext.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x1022a
    2024-08-05 06:21:19 [712ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libomni.ext.plugin.so!carbOnPluginPreStartup+0x1223
    2024-08-05 06:21:19 [716ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libomni.ext.plugin.so!carbOnPluginPreStartup+0xd6cc
    2024-08-05 06:21:19 [719ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libomni.ext.plugin.so!carbOnPluginPreStartup+0xe733
    2024-08-05 06:21:19 [723ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libomni.kit.app.plugin.so!std::string::compare(std::string const&) const+0x96f3
    2024-08-05 06:21:19 [727ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libomni.kit.app.plugin.so!std::string::compare(std::string const&) const+0xa0cf
    2024-08-05 06:21:19 [730ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libomni.kit.app.plugin.so!_init+0x64a7
    2024-08-05 06:21:19 [731ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: kit!_init+0x6eb
    2024-08-05 06:21:19 [735ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libc.so.6!__libc_init_first+0x90
    2024-08-05 06:21:19 [738ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libc.so.6!__libc_start_main+0x80
    2024-08-05 06:21:19 [739ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: kit!_start+0x29
2024-08-05 06:20:54 [2,005ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INCOMPATIBLE_DRIVER
2024-08-05 06:20:54 [2,005ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2024-08-05 06:20:54 [2,005ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
So, does A30 not support Isaac Sim?
Thank you.
by the way, info output from nvidia-smi:
| NVIDIA-SMI 550.90.07 Driver Version: 550.90.07 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A30 Off | 00000000:36:00.0 Off | 0 |
| N/A 32C P0 31W / 165W | 4257MiB / 24576MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA A30 Off | 00000000:37:00.0 Off | 0 |
| N/A 34C P0 31W / 165W | 1257MiB / 24576MiB | 0% Default |
| | | Disabled |
| 2 NVIDIA A30 Off | 00000000:9B:00.0 Off | 0 |
| N/A 35C P0 31W / 165W | 8075MiB / 24576MiB | 0% Default |
| | | Disabled |
| 3 NVIDIA A30 Off | 00000000:9C:00.0 Off | 0 |
| N/A 35C P0 30W / 165W | 5027MiB / 24576MiB | 0% Default |
| | | Disabled |
also there are some RED lines from the docker console:
2024-08-05 06:33:38 [1,734ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INCOMPATIBLE_DRIVER
2024-08-05 06:33:38 [1,734ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2024-08-05 06:33:38 [1,734ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
after run the command ```
$ ./runheadless.native.sh -v
2024-08-05 06:33:38 [2,266ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create any GPU devices, including an attempt with compatibility mode.
after clean up all and reinstall the driver, ./1.3.290.0/x86_64/bin/vulkaninfo --summary outputs:
‘DISPLAY’ environment variable not set… skipping surface info
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
VULKANINFO
Vulkan Instance Version: 1.2.131
Instance Extensions: count = 19
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_EXT_swapchain_colorspace : extension revision 4
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Instance Layers: count = 4
VK_LAYER_LUNARG_standard_validation LunarG Standard Validation Layer 1.0.131 version 1
VK_LAYER_MESA_device_select Linux device selection layer 1.2.73 version 1
VK_LAYER_MESA_overlay Mesa Overlay layer 1.1.73 version 1
VK_LAYER_NV_optimus NVIDIA Optimus layer 1.3.277 version 1
Devices:
GPU0:
apiVersion = 1.3.277
driverVersion = 550.90.7.0
vendorID = 0x10de
deviceID = 0x20b7
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = NVIDIA A30
driverID = DRIVER_ID_NVIDIA_PROPRIETARY
driverName = NVIDIA
driverInfo = 550.90.07
conformanceVersion = 1.3.7.2
deviceUUID = 910070c2-51eb-3f27-be32-49fb8f46e531
driverUUID = b5230ae0-e881-58d9-92be-f74e3e88076f
GPU1:
vendorID = 0x10005
deviceID = 0x0000
driverID = DRIVER_ID_MESA_LLVMPIPE
driverName = llvmpipe
driverInfo = Mesa 21.2.6 (LLVM 12.0.0)
conformanceVersion = 1.0.0.0
GPU2:
vendorID = 0x10de
deviceID = 0x20b7
driverName = NVIDIA
deviceUUID = 0e878d51-8517-7b59-a782-5f1e25a7d007
GPU3:
vendorID = 0x10de
deviceID = 0x20b7
driverName = NVIDIA
deviceUUID = 1774b537-0742-ff75-b7d1-40bd44d33f6a
GPU4:
vendorID = 0x10de
deviceID = 0x20b7
driverName = NVIDIA
deviceUUID = 23416cff-1a1f-8502-dc2b-26a51a842bdd
GPU5:
vendorID = 0x10de
deviceID = 0x20b7
driverName = NVIDIA
GPU6:
vendorID = 0x10de
deviceID = 0x20b7
driverName = NVIDIA
GPU7:
vendorID = 0x10de
deviceID = 0x20b7
driverName = NVIDIA
GPU8:
vendorID = 0x10de
deviceID = 0x20b7
driverName = NVIDIA
However, I still got the error: VkResult: ERROR_INCOMPATIBLE_DRIVER
the docker of isaac-sim is 4.1.0
also tried isaac-sim is 4.0.0, exactly the same issue
I also encountered this problem?Did you find the solution?
still no luck at this moment. :(
I’m still stuck in this place, it’s too uncomfortable. I have found some solutions from others, but none of them are suitable for me
According this topic, A100 is not supported because it does not have RT core.
Does A30 have more RT core than A100?
I believe not. Please check this link:
Nvidia’s A100 Gets Baby Brothers: The A10 and A30 | Tom’s Hardware (tomshardware.com)
They say both A100 and A30 have NONE rt cores.
Yes you have to have a GPU that is RTX based, with RTX capability. Otherwise it will not work.
