About composer flash failure
Hello, everyone. When I open comporse, it crashes and flashes. I want to know what I can do to get back to normal. This is my first time to use the software before this I have tried to install and uninstall the software for many times, but to no avail, I found that after entering the interface of the software, the progress bar in the lower right corner shows that I do not have enough memory, does the memory here refer to the computer running memory? I have 16 gigabytes of RAM. Thank you for your attention to this issue. I’ll paste the log as an attachment below.
omni.kit.extension.log (957.5 KB)
omni.kit.internal.log (1.1 MB)
omni.kit.log (5.8 KB)
omni.processlifetime.log (4.0 KB)
After I entered composer, the progress bar in the lower right corner was very occupied, and the memory kept increasing no matter what I was doing.
These logs are not the correct ones. Give me your complete system specs. GPU, GPU DRIVERS, memory, CPU etc, everything.
It probably means your GPU memory, your VRAM.
same question .
GPU RTX2070
I don’t know the location of the journal you said, could you please tell me? I’m not having a flash back issue at the moment, but when I open the usd file, the view interface doesn’t see the image. Yellow lettering appears below
@yuq1 Well for you, your graphics card is far too low. You cannot use OV with just a 2070 GPU. So I am afraid you will not be able to use it.
@2360051808 Everything seems to look normal so far. I do not understand what you are saying about opening a usd file and it just does not show up. You could try resetting your USD Composer settings.
HERE >>
And here is your LOG
Thank you, sir. Although the interface looks normal, but I open the usd file does not display properly. You can observe the lower left corner of the picture I uploaded. A string of yellow fonts appears. He seems to want to sue me that I have referenced the USD file more than twice, so he can’t use it properly.
Ok so like I said, RESET the app with the above method. Then try to use and open a USD FILE that is not in your Localhost. Just open some regular sample file.
You have to make sure you can start it with THIS CHECKED SCREEN. Or it will not work. And then if that works, try to open a SAMPLE file.
Thank you for your help. I’ll try. In fact, if I didn’t open the usd file, my interface would appear just like yours, and I was able to use things like cubes and cylinders. Well, I’ll keep an eye on that. Also, I would like to consult. If I want to have a better modeling experience, should I use a higher class graphics card, or a card with larger video memory? For example, 4060ti16g or 4070super12g, which should I choose?
I cannot comment on that
