The USD Composer crashes
The USD Composer created via the kit-app-template always crashes a while after launch—sometimes in a few minutes, or in just seconds.My GPU is an RTX 4060 Laptop, the operating system is Win11, and the NVIDIA driver version is 581.57
the log info as follow:
Hi there. I am sorry you are having issues. You say you are on a 4060. That really is below our minimum specs, because it is very low VRAM. 8GB is just not enough.
Looking at your log screen, you can see where it says:
Reasons for the failure: a device list, out of memory, or an unexpected bug
This is highly likely that you just ran out of VRAM. Maybe you were opening quite a large scene. Unfortunately, there is not much that can be done, with 8GB.
